Results 1 to 10 of 19
Thread: wheel locking nuts
    grantham
    Default wheel locking nuts
    went to change the front pads this afternoon. but the previous owner or garage has put the locking nuts on with an air gun. making it impossible to get them off with a normal socket and bar, without chewing them up or even shearing them off. will go to a garage in the morning and ask them to take them off with the air gun. WHY DO PEOPLE DO THIS??? Its a good job i didn't get a puncture in the middle of nowhere. they are Vauxhall locking nuts. has anyone had a problem with these seizing on??? or is it because they have been put on with an air gun??
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    once you get them off change them for a better set the vx ones are really poor quality
    Regular Member squekey's Avatar
    bedfordshire
    They should'nt be a problem if they have used an air gun to do them up as normally they would do them up with an air gun and then torch them up with a torch bar as air guns dont tighten them up as much as they should be. Don't know about the VX locking nuts as i have never used them as i always buy mine from halfords for about £35-40
    Sodding Typical on Sea
    To be honest I have taken the lockers off completely as I never leave the car in an unsecure location nowadays and in the past I have had incredible hassle with moron airgun locknut's
    Wait and see this will come back to bite me now
    East Midlands
    When a wheel is removed by a tyre fitting place,thay have to torque the nuts upto the required setting,in the Vectras case,this is 110 nm,if the wheel nuts are not torqued up to this setting,then if a wheel happens to fall off they could be liable,this is why wheel nuts are tightened to the correct limits.
    In a house
    Quote Originally Posted by macdad View Post
    Dont wish to sound too harsh but, if you believe that, you'll believe anything.
    grantham
    i always thought the normal wheel nuts are on tight to hold the wheel. and the locking nuts are just pinched up so you can get them off with the key. a lock nut just being pinched up is enough to stop idiots from nicking ya wheels. putting them on that tight is just stupid. thats the way ive always done mine.
    Regular Member mr.ian's Avatar
    Ayrshire
    Locking nuts are pointless, if somebody wants your wheels they'll take them easily enough, locking nuts or not! Still use them though.
    Regular Member mikeeaston's Avatar
    widnes
    Quote Originally Posted by Saxman View Post
    i did 4 years in a garage and the only thing i used a torque wrench on was head bolts lol
    Ive watched a tyre fitter in quick fit winding in the wheel bolts using an air gun and then going round all the bolts with a torque wrench, every one was obviously over the specified torqe as the wrench gave way as soon as any pressure was applied without any movement of the wheel bolts. He said "thats the way I always do it sir".
  1. locking wheel nuts
    By Liam1984 in forum Suspension, Wheels & Brakes
    Last Post: 5th April 2010, 20:35
  2. locking wheel nuts
    By tommy tess in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2009, 19:19
  3. Locking wheel nuts
    By johnny kebab in forum Suspension, Wheels & Brakes
    Last Post: 2nd June 2008, 19:03
  4. locking wheel nuts
    By John35 in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2007, 22:14
  5. Locking wheel nuts
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2005, 16:33
