Thread: wheel fitment
    Aug 2009
    Durham
    Default wheel fitment
    looking for some help never fitted aftermarket alloys so not sure if these are ok are not. the stud pattern is right and the wheels fit but the centre of the wheel is to big so the bit of the hub that fits in to the wheel has loads of play is this ok. sorry if this doesnt make sense and is a stupid question.
    cheers for any help
    Regular Member ballan22direct's Avatar
    isle of lewis
    You prob need spigot rings mate. They should have been with the wheels. What make are they? And where you get them from?
    Aug 2009
    Durham
    there second hand with got them for my birthday. there fox rs vr5 19". one is on the car the other 3 are waiting to get sprayed. what do spigot rings do are how much are they
    cheers for the quick reply
    Sodding Typical on Sea
    Spigot rings fit (slide) over the centre hub on the car and take the play up to stop the wheel moving about as when you bolt the wheels on they will go to one side and vibrate.
    If you cannot get official spigot rings quickly, get a beer can cut into strips round the can 10mm thick then tape them end to end (probably three or four will do then wind them onto the hub and tape them into place with duct tape to hold them until the wheel is slid over them this is a cheap emergency spigot fix!
    Aug 2009
    Durham
    ive got my standard sxi wheels still so will get some sorted as soon as thanks for all the help thought i had wasted money there. how do i measure what size rings i need
    you need calipers to measure the dia of the inside of the wheel centre and buy spigots to suit if you can't get them by quoting the manufacturer to a wheel specialist
    isle of lewis
    If you contact a wheel shop either online or localy they should be able to sort you out mate.
    Aug 2009
    Durham
    cheers for all the help does any one know the bore says of the vectra hub so i dont have to measure it cheers
  1. Wheel Fitment...
    By weverall in forum Styling
    Last Post: 5th January 2012, 20:35
  2. wheel fitment
    By marc7 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2009, 17:14
  3. Wheel Fitment Question
    By lillie in forum Suspension, Wheels & Brakes
    Last Post: 24th July 2008, 21:43
  4. wheel fitment
    By cookiejar31 in forum Handling & Braking
    Last Post: 5th June 2008, 16:17
  5. wheel fitment
    By Silver V in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2007, 19:39
