Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Silly Question regarding EDS Maps...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Default Silly Question regarding EDS Maps...
    I plan to totally blank my EGR valve - I know this will bring up EML/Emmisions light - if I then got the 190 (no EGR) map from EDS, would this put the light out....???
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yes
    EVERYWHERE
    Be careful when fully blanking or turning off the EGR valve as the resultant increase in exhaust gas temperatures (EGTs) have been known to cause turbo failure.
    One of the purposes of the EGR system (other than to reduce emissions) is to lower combustion temperatures when the car is being driven at part throttle (cruise mode). The exhaust gases mix with the incoming fuel and partially 'smother' the combustion process. If this is not happening, then combustion takes place at normal high temperatures and hotter exhaust gas is then directed towards the turbo.
    Cambridgeshire
    Quote Originally Posted by diesel dog View Post
    I have heard of this as well.
    Because I've de-Catted it would this reduce the temperatures near the turbo anyway?
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Are you saying it is not wise to disable the egr? I have a EDS map with egr disabled, so curious as to what you are saying. I am also gonna decat with duplex exhaust. Having only mapped the other day I did notice it runs a little hotter.
    Cambridgeshire
    Quote Originally Posted by CHRISK View Post
    Get it de-Catted mate and it should run a little cooler and better I did notice ever since I got mine done i've found that it does run slightly cooler and sounds sweeet
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    You can have the 190 or 200 with the EGR disabled as that is the options I have but I do have the IPF hardware for the remap
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Quote Originally Posted by parsco View Post
    Thats the plan, just waiting on Rich to get back to me.....
    Can't win with the EGR by the sound of it, soot up your engine or run a liitle hotter....be nice to find out the facts proper. Might contact EDS and see what thee take on it is.
    Lancashire
    Trim : XP NAV
    More scare-mongering.... EGR by-passing on BMW's, Range Rovers, Fords has shown no terminal failures of engines/components due to EGR function being disabled, but many pluses have been proven - going off what you say then, whats cheaper, a new turbo or new inlet manifold arrangment
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    I just read an article that said egt increase was minimal, but was 9 years old on Passat forum
  1. Probably a silly question but ....
    By Liamalone in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2012, 19:46
  2. Silly question
    By Angel1368 in forum Tuning
    Last Post: 8th May 2012, 21:10
  3. Silly question
    By Das in forum Detailing and Car Care Discussion
    Last Post: 28th July 2010, 23:05
  4. Maybe a silly question???
    By bigstorer in forum Bodywork & Interior
    Last Post: 28th May 2010, 12:18
