Thread: Incorrect Part Number for Air Con Seal on forum
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Default Incorrect Part Number for Air Con Seal on forum
    Just ordered a seal for replacing my condenser but the part is wrong.
    Part No: 24436645 is the wrong size for the Z19DTH Engine.
    If changing the condenser only you'll need the following seals:
    24436644
    24436646
    Really easy job to do yourself if the system is empty.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    What size are the seals buddy? I'll update them
    @home
    Engine : 1.9 CDTi
    I'll let you know when I check them at the dealers.
    Regular Member um20's Avatar
    Mar 2007
    Doncaster
    Top stuff Lofty, looks like I'll be doing this repair soon so have just noted down those part numbers!
    @home
    Engine : 1.9 CDTi
    Quote Originally Posted by um20 View Post
    You'll only need the two seals if you're leaving your existing drier on.
    The seals are £15 and £3 approx the £15 one being the top one that is most used. There is hardly any diff in size and it's obvious they're charging through the nose for the more common part!
  1. Part number?
    By brotherkennyh in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2010, 09:08
vectra c what air conn seals do i need
vectra c forum air con
vectra c air con seals
