Results 1 to 10 of 20
Thread: V6CDTi - Oil level sensor playing up or not enough oil?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default V6CDTi - Oil level sensor playing up or not enough oil?
    Was driving around Germany and a couple of times the oil light came on. Upon inspection WITH THE ENGINE RUNNING the oil level was on low. If I left the warm engine sitting for 5 minutes (as instructed for an oil check) the oil level was max and the oil level light was off.
    Is this a sensor playing up or is there really not enough oil? Serviced it 5k ago and done most of the miles the past week. Mobil 1 5w50 oil.
    Sounds like the sensor mate. Possibly best idea after all the driving round 'Germany' is to change the oil anyway so you know definintely how much is in there, then see if it still comes on.
    You do smoke a lot...
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    No smoke no poke And I mean some serious poke Hit 150mph earlier today
    Never check the level with the engine running, always when it's warm and it's been stopped for a few mins, maybe 10 iirc.
    Mar 2007
    Beaconsfield, Bucks
    As Big Sig says, leave it 10 mins with engine off before checking. I made the mistake of panicking after checking the oil too quickly after stopping the engine and overfilled mine. There a plate by the bonnet latch saying the same thing.
    Oct 2009
    Bilbao&Madrid
    Trim : Cosmo
    Engine : 3.0 CDTI Z30DT
    Quote Originally Posted by Celes View Post
    Sorry if I'm asking a stupid question, but which oil light? The one that indicates a problem with oil pressure (red) or with the oil level (yellowish)?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I wouldn't be back home if it was the red light
    What confuses me is that the oil level really is on MIN, but goes to MAX 5 minutes after the engine's been off. I think the sensor gets confused somehow. I'll put it on opcom later to see if there's a problem
    Oct 2009
    Bilbao&Madrid
    Trim : Cosmo
    Well, considering it has 7.5 litres inside, it's not hard to imagine there is one litre circulating when the engine is running. In fact, when the oil level ("cool-measured") is not on MAX, it's possible that the oil level in the dipstick is below MIN with the engine running... and the oil level light shouldn't be warning you. I don't know where the level sensor is located, but either something is blocking oil access or the sensor is failing.
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Mine did the same thing while driving in France. Scared the living daylights out of me, but the level was fine.
    I think it's another little gremlin in the sensor.
    Phil
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I think someone put the wrong type of coolant in mine so you should imagine the face I made when I opened the expansion tank and all that white foam came out. Not nice when you're 1000 miles from home
    I'll be servicing it in 2k Oil + filter and coolant
  1. For Sale: AFL level sensor
    By plasma in forum Parts for sale
    Last Post: 11th October 2012, 16:50
  2. Oil level sensor ?
    By draca in forum Engine & Drivetrain
    Last Post: 2nd September 2011, 07:51
  3. Where is the Oil Level Sensor
    By rocket999 in forum Engine & Drivetrain
    Last Post: 30th August 2011, 20:07
  4. self level sensor?
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2010, 19:54
  5. Oil Level Sensor
    By Gavin1977 in forum Engine & Drivetrain
    Last Post: 17th June 2008, 14:14
