anyone know the bore sizes of a 2.2 non direct and a 2.2 direct????
thanks
thanks
Sorry mate I can t remember, can you not just measure the circumference of the 2 pipes?
I cud I haven't got the pipes to measure I'm at work atm and wanna make up and sleeve to join the Y section off the 2.2 direct to mine
You might not need a sleeve if there different sizes.
not sure mate but, gsi and cdti are exactly the same-57mm o/d.....hth
na your rite i wont i have just measured the bore on my car (2.2 Non) and its 51mm im sure i have read somehwre that the direct is the same size bore.
A bit more info.... I recently fitted a twin exhaust from a 2.2 direct petrol to my 2.2 deisel and it fitted without modification.
hth's.... Jon
