Thread: swirl flaps
    KENT
    Default swirl flaps
    Poated a thread a couple of weeks ago and some one said to check my swirl flaps am getting to that shortly anyway my question is can they be removed and discarded I know it can be done on BMW's and you just loose a bit of low end torque but dont know about 2.2 signum can anyone help????
    cheers
    Dave
    KENT
    Bttp
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    i dont think you can remove the swirl flaps from the engine fella
    Aldermaston (Berks)
    I thought it was only the 150's that suffer from this!
    KENT
    That may be but Ive checked and done everything else, fuel pressure is fine even when car goes into limp Ive had a live gauge onit and pressure is still up 02 sensors are working (switching within spec) fuel pressure regulator is brand new ect ect yet over 3000 rpm quite quickly vehicle starts playing up sometimes goes into limp turn off turn back on most of the time sorts it providing I dont go over 3000 rpm but if it doesnt sort it straight away it massively overfuels its already melted one cat then turn it off for 10 mins its fine again (providing I dont go over 3000 rpm) one code that kept coming up I think it was p1109 which is a fuel code and seeing as the swirl flaps start working at 3000 rpm it is definately pointing towards them not working properly (I reckon) before I rip it apart and check has anyone got atest procedure and location of the actuator? ive seen one on here for a diesel but not a 2.2 direct petrol.
    cheers
    Dave
    Aug 2009
    LEEDS
    iv herd of it on bmw's as my mates snaped a couple of year ago and did his engine and turbo in but not herd of removing them on anything else
    Regular Member squekey's Avatar
    bedfordshire
    easy dave
    I got a similar problem with my vec 2.2direct sri soon as i hit 4000rpm and hold it then the car judders and if i keep my foot on the throttle my engine management light comes on thankfully the car has never gone into limp mode though, soon as i switch the car off and restart it the EML goes out, i know the previous owner of the car had vauxhall replace the swirl flaps on mine as i have the invoice to show it. A few people have said sounds like fuel pump problem but not sure m8ty
  1. hello to all and swirl flaps
    By hasbin0796 in forum Introduce yourself.
    Last Post: 11th March 2012, 16:31
  2. swirl flaps?
    By mickyblueyees in forum Engine & Drivetrain
    Last Post: 20th January 2011, 18:01
  3. Swirl flaps
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2009, 19:13
  4. Swirl Flaps Pt 2
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2009, 18:43
  5. BMW Swirl Flaps
    By Diesel Dude in forum General Chat
    Last Post: 16th March 2008, 11:38
