Thread: Help with EGR fault clearing please?
    Swindon
    Default Help with EGR fault clearing please?
    Hi,
    I am a newbie so please be gentle. I have used some really good data on this forum to remove, clean and repair a jammed solenoid on the wifes 1.9 CDTI 150 Zafira. The thing is now working great on a 12V bench power supply in the garage with the valve opening with 12 V applied and closing when the supply is removed.
    I have refitted the EGR to the car - no problems - but the engine symbol remains lit on the dash and the press brake + accelerator while turning the key on says the same code.
    Is there anything I can do to put the light out and clear the code without having to spend money at VX ???
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Disconnect the battery for 15mins
    Swindon
    Thanks for the very quick reply!! I left the battery disconnected for over 30 minutes and then reconnected it. Unfortunately the engine light is still on and same fault code ECN 40065A shows with a pedal test. I presume this means that either a fault condition still exists associated with the EGR, although I'm not sure how it knows since the device is essentially a solenoid that still has the same coil resistance as before it had when it was seized; or that removing the battery in this case does not clear the fault alarm condition in the ECU. Another possibility I guess is that there is something wrong with the solenoid drive signal (12V). I can measure a convincing +12V coming from wherever it comes from (presume it's the ECU wherever that is).
    Looks like I have no option other than to take it to the garage
    Thanks for the help on the forum.
    Regular Member andy-j's Avatar
    Apr 2008
    stoke on trent
    Buy ELM327 off ebay for about £25.
    N.Ireland
    U480 code reader of ebay,great tool for reading and clearing codes.
    Regular Member stuart813's Avatar
    gosport
    I got a mobile mechanic to check my fault codes cost £30 and he also said if it comes back he'll come and check it and clear it for free.
  1. Fault finder/clearing and skill members list
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2012, 12:59
  2. Clearing the EML light
    By Gortreck in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 14:23
  3. Clearing fault codes
    By oxenburger in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2010, 17:59
  4. Clearing nav on a CD70
    By mel in forum Electrical & ICE (including SatNav)
    Last Post: 3rd August 2007, 23:30
  5. Clearing It Up
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2006, 18:32
