Results 1 to 10 of 24
Thread: can someone help please
    Jan 2010
    cumbernauld
    Question can someone help please
    hiya,
    just did the airbox mod on my 1.8 sri. it sounds like an induction kit or as if i just took everything off to the throttle body or something. by that i mean its a bit louder and it makes that loud sucky noise. the thing im worried bout is that i didnt know that happens so is it meant to happen? only way could be bad news is if its NOT meant to cause i do like it just makein sure its normal.
    thanks guys,
    Regular Member old cruiser's Avatar
    slough
    Did mine on my 2.2 and made a slight difference in the sound but not agreat deal to be honest, but maybe the 1.8 is a slightly different setup, if you're worried it might be worth double checking that you've put the airbox back together properly including the air intake pipe and filter in case it's leaking as it were, failing that if there's no difference in it's performance then put the trumpet back in.
    Cheers Pete
    Jan 2010
    cumbernauld
    cheers bud, will go double check again. kinda sawed the trumpet off so dont think a can realy put it back on.lol. dont imagine anything could be much different. enough to make a difference anyway.
    if anyone else has anything to ol cruiser would be as apreciated as he is, thanks buddy
    slough
    Incidently it is the one in the airbox itself i.e below the filter that you removed wasn't it and not in the lid?
    Cheers Pete
    Jan 2010
    cumbernauld
    both. did the clipy one a while ago and someone whos name i forgot said should try the top too. so hacksawed it. everything is attached properly tho and can feel a tiny tiny bit of air passing my hand at the very front intake, you know the one behind the grill, suggests to me that it means the airflow is in the correct place rather than leaking in. so hopefully is filterd well enough, are you not meant to remove the one on the lid??
    Sep 2009
    Glasgow
    you loose power torqe if you remove the trumpet
    Jan 2010
    cumbernauld
    awryt, er, oops, lol. its gt to be restrictive though dont understand how it will loose power letting more air in.
    Sodding Typical on Sea
    The horn creates a venturi effect and acts to suck the air accelerating it and making it denser as it enters the induction phase, it's not going to kill the engine or anything from my understanding but does result in the noise you have described and a slight loss of power but unless you are on a rolling road or a track day most folks wouldn't notice any difference.
    Jan 2010
    cumbernauld
    that makes sense. well il time 0-60 tonight and c what happens. quickest ive done is 9.7 and i average 10.2 after counting 5 times so will see what happens.thanks guys
    slough
    Quote Originally Posted by peterAC View Post
    Not so sure it's a good idea to have removed the one in lid as I thought this one had a mesh in it to protect the Maf sensor unless of course you still have the mesh there if you hacksawed just up to it.
    Cheers Pete
