Results 1 to 10 of 13
Thread: Cleaned out the EGR and fitted Fiat Gasket today
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Cleaned out the EGR and fitted Fiat Gasket today
    Well second time I have taken my EGR Valve off to clean and I found................
    Nothing, Valve was lightly soiled but that was it (same as the first time).
    Just for the fun of it I fitted the Fiat restrictor Gasket and then gave it a blast up the road and no issues.
    I am sure most of the issues with the EGR Valve in the first place are caused by the way the car is driven. Mine is driven hard and does a lot of motorway mileage so I think thats why it is so clean.
    1.9 CDTi 150 2005 full canbus BSR remap 125k miles
    Will keep you all up to date if the Fiat Gasket causes any problems
    May 2010
    Sodding Typical on Sea
    I would agree with the soot build up and puddle jumping, long drives result in clean exhaust gasses relatively speaking, so makes a lot of sense.
    Dec 2007
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    going to take mine off nxt week! to have a peep (x 2 fiat semi's fitted), im due a run to devon at the end of that week so will also have a good blast.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    For reference the gasket part number I used was 55225287
    Mar 2010
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Been reading about V power diesel and redex etc on here lately, do you use either? Bit the bullet and put £35 of V power derv in this morning ready for a weekend run, to my surprise it does seem to run better.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Grumpy1954 View Post
    tried some millers diesel sport for about 4 tanks fulls, my mpg dropped 3-5 mpg. Will not be doing that again. Made no difference to the running either. Normally fill up at Tescos so no I dont use V power or the BP stuff
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Quote Originally Posted by merikiito View Post
    Will this be the same for a 120 bhp if so do I get this from a fiat dealer and at what price ?
    Thanks Steve
    Regular Member bunsen1's Avatar
    May 2010
    suffolk
    few quid, only paid 6.50 for oval semi blanking and standard one
    Regular Member OPC's Avatar
    Mar 2009
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Year : 2008
    I notice the oval gasket is metal, is this fitted on it's own?
    May 2010
    suffolk
    i fitted mine on its own, others have put a standard ones on as sandwich with it. maybe even just put the old one back on too to seal more firmly,
  1. Fiat EGR Gasket Question....
    By Dan_BlackSRi in forum Engine & Drivetrain
    Last Post: 9th August 2012, 16:25
  2. Fiat EGR Gasket for a 150 CDTI
    By AntSSSS in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2012, 10:04
  3. Fiat EGR Gasket
    By bafoo in forum Engine & Drivetrain
    Last Post: 20th January 2011, 16:51
  4. Cleaned the estate today and fitted few bits
    By damers2000 in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2010, 21:27
  5. Fitted Fiat EGR gasket.
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2009, 19:58
