Thread: Parking Lights
    Regular Member bunsen1's Avatar
    suffolk
    Unhappy Parking Lights
    Hi, first ever post so bear with me, i have owned my 2004/54 vx vectra 1.9cdti 150bhp for 3 weeks. went out to the shop this evening and as we set off the infostation instaed of displaying the time/date and avg miles per gallon was displaying "parking lights" and also in the rev counter was displaying a symbol to match? any ideas why and also how to get rid of it? cant be a problem can it, i turned the lights on settings dipped and main beam and it didnt go. please help me
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Think you have a side light out matey
    suffolk
    1. where can i get one, anywhere? just popped out for a look now and yep its the front left, what a pain considering when i brought it (wait for it) it needed a new flywheel so had the clutch and slave done too.
    2. didnt use the lights when i went out so im just wondering could it have gone without being used/turned on?
    i thank you for your help,
    3. will the infostation tell me of majority of problems?
    Sep 2009
    Glasgow
    washer level, what lights are out are the only ones i've seen so far
    N.Ireland
    I've had the same problem for a while now,all my lights are working.With minee it just happens when the car is moving along,when the car is stationery are when the lights are turned on it goes away.
    Full Member Big Sig's Avatar
    Its a bulb, they can blow at anytime. About £1.50 for two.
    If it thinks you have one out it will use your indicator in its place - albeit at a lower wattage.
    Glasgow
    Also if it gives you a warning that its blown and you check it but its still working, it will fail shortly.
  1. Parking lights without the fault light?
    By carperjake in forum Styling
    Last Post: 14th June 2012, 22:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. parking lights
    By peterAC in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2010, 00:37
  4. parking lights!!
    By izonoky in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2008, 00:31
