Thread: auto box
    Jun 2009
    warlingham surrey
    Default auto box
    hey every one, please please please help me ,,, i have a 3.2 v6 with auto box and its playing silly ******s,,, keeps going into limp mode bringing up a spanner on the dash and only allowing 2nd and 5th gear to be used ,, if i stop and switch the ignition on and off it will re set and be ok again,,, to start with it was only happening once a week or so but now its 3 times a day,,,i have put it on a snap on diagnostic system but it comes up with unknown error...can anyone help me, ?????
    Regular Member poves's Avatar
    lancashire
    I hate to be the bearer of bad news but that sounds very familiar to alot of peoples experience with the af33 box , myself being one of them.
    It's more than likely the gearbox coolant issue , which was a recall , but a few slipped the net.
    I buried my 3.2 elite at 5 yrs old with 42000 miles on it.
    london
    Default Auto Box
    Check to see if your coolant from the expansion tank is vanishing without obvious leak anywhere, its probably has to do with the radiator seal recall some years back. when the seal gives way, the coolant goes in the autobox. causing some damage. ....It could just be Transmission speed sensors, when these sensors fail, the box defaults to second and fifth gears only....It could be low or expired fluid. Stop driving the car until the fault is diagnosed.
    worst case scenario.........new \ recondition auto box
    london
    The recall wasnt done on my Veccy 2.2 when i bought it, called vx and arranged for it to be done free of charge at about 32k miles.
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Take it tp a reputable auto box specialist and get them to look into it. As said, it could be just a couple of speed sensors which are cheap to fix or it could be the dreaded coolant in gearbox (which will require a rebuild).
    When my autobox started to play up it only happened when it was up to temperature, I cant remember what was wrong with it now but it was not a coolant in box issue. This also reuired a rebuild.
    Essex
    Quote Originally Posted by bigcarman79 View Post
    ..... As said, it could be just a couple of speed sensors which are cheap to fix .....
    Unfortunatley if it is the speed sensors they are not a cheap fix, just under £500 for both when mine went!!
    Of the 4 new ones i've had fitted 2 failed within 2 weeks!
    One of the reasons they fail is due to moisture on them which is caused by the heat exchanger (oil cooler) seals failing.
    Mine failed and needed a re-build. Re-build will cost between £2500 and £3000 inc VAT.
    You could always fit a 2nd hand AF33, plenty of them about, usually found next to the rocking horse poo infront of the hens teeth!
    Jan 2008
    Pontefract
    Quote Originally Posted by stoneshed View Post
    They are about £30-£40(each) for the sensors according to the specialist that did mine.
    london
    The Transmission speed sensors are 'DIYable' . im not sure if it is covered on the how to section on this site, i think its on haynes manual.
    Regular Member crespo's Avatar
    Bournemouth
    Doesnt sound good mate. I have seen so many mint vecs at my local breaker and every one has had an auto box that has killed itself and wrote off the car.
    Hope it works out ok for you fella.
  1. auto wipers, can you fit auto headlights?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2011, 11:32
  2. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  3. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  4. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
  5. Vectra 1.9CDTI 150 Auto v 2.2Direct Auto
    By mattr in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2007, 19:16
