Thread: Steering wheel control fault
    Regular Member bighammerfan's Avatar
    hillingdon
    Default Steering wheel control fault
    Hi all. I have a 2001 vectra and yesterday the control button on the steering wheel that moves the cd track forward stopped working. It worked a couple of times this morning but nothing now. All the others work fine and the actual button action is working fine just dont move song forward. Any ideas please ?
    Oct 2006
    southampton
    15 Post(s)
    dirty contacts, strip down and clean IMO
    hillingdon
    How do i get it apart ? I dont want to set the airbag off !
    Oct 2006
    southampton
    15 Post(s)
    On the back of the steering wheel is a screw, one on each side, one for each side of the wheel. undo the appropriate one and then just pull out the steering control, be careful of the small plug on the back of the controller. Dont pull too hard as the cable is not that long... HTH
    hillingdon
    I managed to undo the screw (it wont come all the way out but its loose) but i cant seem to get the controls out. any tips ? i have tried to clean connections but it still only works once in every 50 (ish) goes.
    hillingdon
    How do i find the part number for this item so i can buy a new one ? How do i remove the old one ?
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by lizard View Post
    It's a 2001 vectra b steering wheel,not a c
    Quote Originally Posted by bighammerfan View Post
    Before you start to remove these screws behind the steering wheel,you should first disconnect the car's battery terminals.
    You will need to undo both screws behind the steering wheel to remove the airbag,you will have to lift the plastic yellow locking tab up and then pull the plug out,and this will release the airbag from the steering wheel,and then you can get to the control buttons to remove them.
    The torx screw you have already undone won't come out all the way and fall out.
    If you turn on the ignition for any reason,with the airbag disconnected,the eml will stay on,until you get it taken off.
    I do have a few sets of 3 spoke steering wheels controls here for the vectra B,but i'm thinking that your steering wheel might be a 4 spoke.
    hillingdon
    Hi. Thanks for the info. Yes it is a 4 spoke. Is it major job or is simpler than it sounds.
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    Its fairly simple,take off the negative terminal of the battery,to be on the safe side,go and have a cuppa,come back out and undo the 2 torx bolts behind the steering wheel,holding the airbag in place,lift the airbag out a little bit,so as not to pull on the cable,you will then see a yellow plug going into the airbag,lift out the locking tab first,and you can then pull the plug out from the airbag,then you will see the steering wheel controls held in place either side of the steering wheel,with 2 more smaller torxs screws on each one,and they come as a pair,so just disconnect them from the other plug inside the steering wheel,the 4 spoke steering wheel controls are smaller than the 3 spoke steering wheel controls,so the won't fit,you will need to get 4 spoke steering wheel controls.
    hillingdon
    Thanks you have been a fantastic help
  1. steering wheel control help!
    By signum03 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd October 2012, 17:29
  2. Steering wheel control
    By RLT in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2010, 18:10
  3. steering wheel control
    By steeb82 in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2008, 22:32
steering wheel control fault
