Thread: driveshaft support carrier bearing
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Default driveshaft support carrier bearing
    Does anyone know how much a drive-shaft support carrier bearing costs ?
    for a cdti 150
    As I'm sure mine is going
    Regular Member Maxim007's Avatar
    Jul 2009
    Bistrita
    what is your symptoms?
    Why you think your is gone?
    I think they is not very expensive....50 pounds/booth sides.
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 71000
    Hi Maxim
    the symptoms are a bad droning on drivers side front, from 20mph up to 60mph (even the wife can here it now lol )
    its been getting worse over the last 10,000miles it started droning at about 55mph only
    now its getting really bad
    I've swapped the tyres back to front, no change
    I had both front wheel bearings checked out by a garage which they say are fine ? no free play at all
    so I thought it could be the drive-shaft support carrier bearing,
    as after a 10 mile run it got really hot,
    but today I run the just the engine up to 80c & it got just as hot with out a wheel turning (looks like i was jumping ahead of my self again lol) heat transfer, heating it up from the engine block
    I'm now thinking it must be the drivers side front bearing
    I'll have to try a different garage & see what they say
    Cheers for the help
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    did you sort the problem? and was it the driveshaft bearing?
  1. Driveshaft for 2.2 Dti
    By damian s in forum Engine & Drivetrain
    Last Post: 20th February 2010, 18:35
  2. Diff bearing carrier removal
    By simick in forum Introduce yourself.
    Last Post: 17th March 2009, 21:00
  3. 3.0 Diesel Estate r.Driveshaft/bearing replacement
    By NPS in forum Engine & Drivetrain
    Last Post: 9th December 2008, 19:31
vectra c driveshaft bearing
vectra c carrier bearing
has vectra got a carrier bearing www.vectra-c.com
