Results 1 to 10 of 18
Thread: EGR Blanking plate.
    Regular Member stuart813's Avatar
    gosport
    Default EGR Blanking plate.
    Hi does anyone have the part numbers for the blanking plate or plates for 1.9cdti 150. Ordered one off ebay and it doesen't fit.
    Cheers.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Make your own with alu plate or even a coke can etc drill a 6mm hole in the middle and then mark out the other 4holes for the bolts to go through and it's done free too mine works perfect with a 5mm hole in
    Regular Member OSSY's Avatar
    Apr 2009
    Quote Originally Posted by winnie2457 View Post
    Winnie - How long would you expect a coke can cut-out to last for?
    EVERYWHERE
    Quote Originally Posted by OSSY View Post
    Don't use coke can! It's too thin to leave in for more than a few hours driving. Your 6mm hole will grow in size and God knows what the burnt aluminium will be doing to your engine internals. I used 1.5mm stainless for my EGR gasket, with a 15mm hole to make sure I got no spanner light and burnt enough exhaust gas to keep the engine running cooler on part throttle.
    Apr 2009
    Quote Originally Posted by diesel dog View Post
    That's what I was thinking... A coke can would only last a few miles?
    kings lynn, norfolk
    I have used 1mm thick ally plate with only one 5mm hole in so it's practically blanked and have had no lights at all and the ally plate is fine no heat distortion at all and over 15000miles now coke can will be fine as my mates is using that and no probs if you want to be safe then get some ally plate and your egr and inletmanifold in ally if you use steel etc you could end up with disimilar metal corrosion as the atomic number o the metals are different I see alot of this with steel and aluminium at work also on your wheels where they corrode onto the rear drums is a prime example
    EVERYWHERE
    Started off with mine fully blanked and got MAP sensor error. Then took it up to 5mm hole, lasted a bit longer and then got same code. Ditto for 10mm and finally OK at 15mm. V6 obviously has more sensitive sensors.
    gosport
    ok so i need to have a hole in it to stop the spanner light apart from that 1.5mm ally should be fine to use.
    kings lynn, norfolk
    Yup ally plate is fine try a 6mm hole that should be fine if it does put light in then go up anothr mm I have used a 5mm hole and mine is fine so far after 15000 miles
    gosport
    Cool just ordered some ally plate will let you know how i get on.
  1. For Sale: DTi EGR Blanking Plate
    By TonyP2020 in forum Parts for sale
    Last Post: 8th November 2012, 00:10
  2. Egr blanking plate
    By morrisseyno1 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th September 2011, 20:49
  3. Egr blanking plate
    By baz_cdti_sri_150 in forum Diesel Engine related
    Last Post: 2nd April 2011, 19:51
  4. blanking plate
    By lordreeson in forum Engine & Drivetrain
    Last Post: 3rd March 2011, 12:59
