Results 1 to 10 of 29
Thread: Bilstein B4
    Regular Member mishima's Avatar
    UK
    Default Bilstein B4
    Right. I've decided the LS is getting lowered. Going to get some Bilstein B4's to go with springs.
    What I want to know is do I need to be looking for Bilstein B4 that are specific to Vectra C? Look at this link - http://shop.ebay.co.uk/?_from=R40&_t...kw=Bilstein+B4 It seems they are listed against the model of car etc.
    A bit of advice would be appreciated - cheers!
    Winteringham
    why not speek to LMF
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    here is the part number that they need to be. hth
    front right=vneb874
    front left = vneb873
    rears are both the same=bne-b875
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Euro car parts sell them, you wont find cheaper if your picking them up. There is only one set of B4's for the whole Vectra C range mate, so as long as to get the Vectra C ones and the specific left and right fronts you wont have a problem. If your getting springs from LMF then you might as well get everything from them as they only charge £10 for delivery for the lot, doesn't matter if you but one item of a full set of shocks and springs.
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    confused
    Aren't the B4's the same spec as the standard shocks ?
    I thought that B6's were the ones to use if you wanted to uprate/upgrade from the standard ones.
    Regular Member g33had's Avatar
    I've lowered my car on -40mm springs on standard shocks and the back still looks rather high, even sat next to other Vectra's :'(..... i think its my standard shocks, so these are on the agenda, car is a 2.2i LS aswell.
    Nov 2007
    telford,
    compared to an sri u have only dropped 25mm and if u haven't got the correct springs for the axle weight then the car will sit higher matey.
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    I looked at B4's but then decided on Koni Yellows. (With Eibach pro kit) Fully adjustable and will never go back.
    Decided to go koni after I was told B4's were essentially factory shocks.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by g33had View Post
    Shocks have no affect on ride height mate, only when there compressed and hit the bump stops.
    Just really annoying that it doesn't look very low on the back lol. Front sits perfectly tbh.
    Springs were stated as 1.8/2.0/2.2 and i have a 2.2 so i guess why it sits so nicely on the front lol. Rear makes me sad! :P
  1. Bilstein B4
    By Sebastian in forum Handling & Braking
    Last Post: 16th October 2010, 19:06
  2. Bilstein B4 - Where to buy?
    By mishima in forum Handling & Braking
    Last Post: 11th July 2010, 21:36
  3. Bilstein B4 - which ones?
    By taiko in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2010, 00:07
  4. Bilstein B6......
    By david.aka.judas in forum Parts for sale
    Last Post: 21st March 2010, 10:00
  5. Bilstein B4
    By DarrenLee in forum Handling & Braking
    Last Post: 19th March 2008, 00:19
vectra c bilstein b4
