Thread: Ball joint separator for track rod ends
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Question Ball joint separator for track rod ends
    I am going to replace my NSF track rod end this weekend, from reading threads on here i understand i need a 'ball joint separator'. I do not currently have one of these tools in my arsenal so need to buy one. On the bay i can see a massive variation of types and sizes, can anybody make a recommendation for me on the size and type i should buy.. Prices vary from £4 to £144, personally i am looking towards the budget end as the only time I am ever likely to use this sucker again is to do the other side..
    Wherever i buy it from I need to have it by the weekend... So if its a Halfrauds jobby then so be it, VX have yet to call me back with their crazy quote for doing the job.
    Regular Member Jezzy's Avatar
    S.E
    Don't bother - I bought a Laser one from Halfords for exactly the same job as you're planning (TRE), but when I came to do the work the ball joint seperator turned out to be too small (the "jaws", if you will, weren't far enough apart), so I borrowed a trick from TV's Edd China and hit the TRE from the side to break the tension, job done.
    S.E
    Aug 2009
    on the hills
    All you need is a decent hammer!! unfasten the locknut on the T R END then with a swift clout hit the hub carrier where the t r end is mounted and out it will pop, you may find it a little easier to put the steering on full lock so as to get a good view of the t r end, hth keith.
    ps don`t forget to slacken the locknut on the steering rack first
    Jun 2009
    South Coast
    cheers guys, was advised about the hammer trick this evening but will borry a tool just in case..
    How long does this job take, I think it should be about 20 minutes if no probs are encountered... VX came back with a labour only quote of £126, i told them they were 'taking the p155' and they said they would go and check the system and come back to me to confirm the time it takes etc..
    Aug 2009
    on the hills
    yep, 20/30 mins should see it done, and don`t they know how to charge!!
  1. Offside track rod end ball joint has slight play
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2011, 19:08
  2. Replies: 5
    Last Post: 15th July 2010, 21:33
  3. Track Rod Ends or Inner Track Rods
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 28th April 2010, 11:41
  4. Track Rod Ends
    By Cat_J in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2010, 01:14
  5. Track rod ends
    By Kermit in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2008, 18:00
https:www.vectra-c.comforumshowthread.php111343-Ball-joint-separator-for-track-rod-ends
