Results 1 to 2 of 2
Thread: hoses pics
    belfast
    Default hoses pics
    hi there, could any1 tell me if there is a picture posted at any time with instructions on all the hoses, pipes etc that need to be checked. my 04 vectra 2.2dti has been cutting out. i have removed and cleaned both the throttle body and egr vavle, but its still cutting out. the garage said initially it was the throttle body, and after a second diagnostic, it is now coming up with ecu malfunction, diesel pump and throttle body. WE R NOT AMUSED!
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Normally its the small vacumm rubber hoses that split, if you look under bonnet you will see small plastic pipes joined with small rubber hoses. These all need to be checked for splits (a common problem). Normal culprits are the two straight ones up near the slam panel on the battery side of the car HTH. I had this n my 2.2 DTi and also the pipe had become disconnected off the vacumm reservoir. Sorry no pics.
  1. hoses
    By HARRY SRI in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2012, 15:27
  2. 2.ot boost hoses intercooler hoses
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2011, 23:21
  3. 1.9 SRi 150 Hoses
    By Imi in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2008, 12:11
