Thread: pre face angel eyes
    Regular Member *enery*'s Avatar
    Mar 2007
    glasgow
    Default pre face angel eyes
    i have a set fitted.had them for over a year now.im wondering if anyone has changed the rings to leds?to give a more blue/white light?and can it be done without putting on the bulb computer?
    cheers guys.
    Rab
    Hanging Heaton / Batley
    14 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Sure someone did this recently to a more blue white, just looked couldn't find the thread...
    As for warnings, if your's doesn't now i'd guess it should be ok if replace like for like SMD/led's. Must have something already build in... And you could always hard wire them pretty easily if the warnings come up...
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    I did mine but I have now gone back to the original ones as I was sick of the warnings for them. They flash when not on and also flash when car is totally off. also throws a bulb warning. there is a way around it with resistors but couldn't be bothered with the hastle
    http://www.vectra-c.com/forum/showthread.php?t=103616
    14 Post(s)
    Mileage : 110k
    Do either of you have heated seats? If not have a look under your rear ashtray/power socket. If there's the brown and green blocks for the seat there's a 5 min fix for all these warnings!!
    Mar 2007
    glasgow
    na i dont have heated seats..is there a wiring diagram or a good how do on how its done?i dont want strobe lighs and warnings.
    Quote Originally Posted by leemarksmith View Post
    will look now. But I dont have heated seats. But please enlighten me.
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    If you use a relay for the leds in angels and put and original bulb in fog light connected to sidelight circuit you dont get bulb out warning,
    14 Post(s)
    Mileage : 110k
    well if you look at the blocks (if you have them) there's 5 wires on each block, you need to take a live feed from the middle yellow one, and then an earth from one of the 2 brown wires (or somewhere under the bonnet if prefer).
    So basically run some speaker wire from these, under the center consol, behind the glove box and engine bay. hook up the right way round to your lights/leds and job done...
    The yellow is illumination live, will come on as soon as you turn the side lights on. also should come on when press the key fob (same as dash lights)
    Should get no warnings etc... You could even take the feed from the cig lighter if want them as daytime lights when ignition is on. But thats up to you... i always put my lights on anyway - habit...
    Will take all of ten mins to run the speaker wire to where you need it... have been meaning to do a how 2, but i'm doing my fogs as DRL's at same time running all LED's so has been on hold till i pick up some extra bits...
    14 Post(s)
    Mileage : 110k
    By the way. to do an easy test... stretch out the metal on a bulb or led, then jam the pins down the yellow and brown block. then test away with your light switch and fob... just make sure its right way if led's...
    You'll see it works before stripping everything, i'll take some pics or a video later if need to. bobbing out now
  1. Pre face angel eyes
    By accveccysriturbo in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 10:56
  2. Angel eyes
    By c_maxx in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2010, 16:09
  3. Angel eyes
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2010, 20:42
  4. Dark Pre-Face Angel eyes for sale
    By arkhan78 in forum Parts for sale
    Last Post: 20th January 2010, 10:54
  5. Angel Eyes
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2008, 11:19
