Results 1 to 10 of 11
Thread: The Ultimate Signum Exhaust question...
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Question The Ultimate Signum Exhaust question...
    Right... been an hour or so of browsing through old threads but I still can't find a definate yes or no answer.
    I am after a replacement exhaust for the Signum and like the look and sound of the Millteks... Now for the question.
    Is the Signum exhaust the same as the Vectra estate... apart from needing a chop on the tail pipes?
    I already know the standard Vec Exhaust won't fit... Thanks
    Bordon, Hampshire
    Anyone?
    Full Member Big Sig's Avatar
    I believe so, as you say the rear section is longer on the estate.
    Nov 2009
    Norfolk
    The downpipes and cat are the same on Signums and Vectras (hatch+estate)
    From there on its all different.
    The Signum is meant to use a Vectra estate chassis, but I have never seen a vectra estate exhaust fitted/adapted to a Signum.
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Check the Jetex web site!then check the cat back system used by BSR and you may be surprised.Then ring Alan Jones @ Jetex.
    Bordon, Hampshire
    Quote Originally Posted by Super T View Post
    Couldnt find the BSR one, do you have a link?
    May 2007
    On the Levels
    Go to the tuning products for the Signum 20t and look at stage 3.The cat back systems are on that page.Check the part numbers against the Jetex part numbers and you will see they are the sameAnd make sure you order the right tail pipes ie showing or hidden.
    Bordon, Hampshire
    **** Me... it took some searching but I found it!!!
    Main BSR website... http://en.bsr.se/products/40083120/ Item number 083DHAR
    Jetex Website... http://www.jetex.co.uk/website/jetex...tainless+Steel Item number 083DHAR
    However its not listed for a 2.8!!! Grrrrr
    But the Jetex system is listed as a half system? Must be right though as its around the same price as BSR with a very poor euros to the pound exchange rate.
    Bordon, Hampshire
    For all those who have fitted a VXR exhaust from a 2.8 onto another motor i.e. 1.9 or 2.0T... are the pipe diameter/bore sizes the same on both motors so its just a straight swap?
    If so, there should be no problem with me ordering the exhaust listed for every model (bar the 2.8) and fitting that on???
    Nov 2009
    Norfolk
    I got a complete system fitted the other day (from the flexi back)
    Was alot less than either of those prices and guaranteed for as long as I own the car!
  1. signum exhaust question
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2012, 20:50
  2. Signum exhaust question.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2010, 23:25
  3. Where to buy oval exhaust tail pipes for signum exhaust
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 17:16
  4. Signum Exhaust question
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2007, 20:24
