Thread: vectra c o/s rear door /window problem
    SUSSEX
    Default vectra c o/s rear door /window problem
    evening all
    last year my o/s rear window would only work after a good slam. now the window doesn`t work at all and the door doesnt open. the button pops up when i activate the central locking and i can also hear a slight click when the window button is pressed for that window, but nothing happens. any ideas gents
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    loose multiplug at the door connector? open the door and follow the wiring loom where it comes out of the car body to the door itself, give this a good push. But sounds like something it loose or stuck inside... If you come down to the free brentwood show we'll be able to strip it out and have a look for you
    SUSSEX
    thanks for the kind offer plasma, but i`m away fishing that weekend
    how can i open the door if neither handles work lol?
    SUSSEX
    can the multi plug that goes into the rear door be pulled out or am i likely to break something?
    SUSSEX
    any more ideas on this ****** problem
    perthshire
    Default try the door lock pin
    Hi , i have a similar problem on my signum , if i drop the window or stretch across and pull the door lock pin up firmly the door opens , the pin pops up a small amount but not fully when activated by the remote ,i suspect a door card off and lube or a new activator , Alan
  1. rear door window removal
    By Al 22 dti in forum Bodywork & Interior
    Last Post: 30th April 2011, 20:54
  2. door/window problem
    By nastypablo in forum Bodywork & Interior
    Last Post: 2nd April 2010, 14:19
  3. Drivers door window switch problem
    By armbuster in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2009, 14:54
vectra c rear door fault
