Thread: Wiper Linkage
    Regular Member Telboy's Avatar
    Apr 2006
    Leeds
    Default Wiper Linkage
    Has anyone any advice on changing this like how does the plastic panel come of thats covering it all up? One of my linkages rods from the drivers side to the passenger side wiper has go a little worn and keeps popping of.Rang the dealers and its a complete unit and they want £109. I only want a new link rod the robbing sods.Might be a run to the breakers yard or see if I can do a repair on it myself but need to get the unit out first though.
    you remove the wipers , then the seal that runs along the front of the black cowl
    then you have to lift it slightly at the front and pull towards you as it clips under the windscreen and viola you have access
    you dont need to buy a new linkage i believe there is a how to in the how to section on repairing the linkage saving you loads of money !!
    Apr 2006
    Leeds
    Thanks for that Mark I will go check it out as not paying £109 just because on bit has worn slightley.They had 20 in stock so got to be common fault.bet he was rubbing his hands when I asked about them.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    when more than one of the linkages go you will need buy a new set as plastic tie wraps will not longer do the job. You can get them a little cheaper from vauxcentre £91..
    Northampton
    Engine : A20DTH
    Mileage : 88000
    bestgoing for the complete replacement as it will fail again, and you know it will be raining heavy when it happens!
    The new one is a modifed one so it will not happen again
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Mines the same, do what I done just try it and see if it works for you it does for me , use a cable tie and tie it back to the joint. Mines been like it for about 2 months now and the cabile tie has been alright and you can't even tell. Saves you some money
    This should be a recall issue because it aint safe imagine your doing 70 mph and its heavey rain and it pops off ,
  1. Wiper Linkage - failed O/S Wiper
    By silver-tongue in forum Engine & Drivetrain
    Last Post: 15th February 2011, 10:29
  2. Wiper Linkage
    By RS_Turbo in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2010, 19:56
  3. Wiper Linkage
    By parsco in forum Parts for sale
    Last Post: 27th July 2009, 12:51
  4. wiper linkage
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2009, 17:40
  5. wiper linkage
    By vectragsi3.2 in forum Parts for sale
    Last Post: 21st January 2009, 19:42
