Results 1 to 10 of 16
Thread: Changing sri exhaust tips
    Regular Member craig1989's Avatar
    iver
    Default Changing sri exhaust tips
    afternoon all..............
    i have got a 2.2 direct exhaust system coming and i fancyed changing the tip to summin a bit bigger...........can you take the sri ones of and fit diff ones. if so how do you do it????????
    any help would be great cheers all
    craig
    Full Member spennny's Avatar
    Blantyre
    Quote Originally Posted by craig1989 View Post
    craig
    You cant mate, hardly any metal left if you remove the exhaust tips, nothing could clamp there , maybe a weld , but not sure, you would need to change the backboxes
    argyll, scotland
    ill be doing this on wednesday, cutting the old tips off and welding vxr style ones on, anything can be done if you know someone whos good with a welder and will save alot of dosh
    iver
    yeah i was thinking that it could be done, i can weld it at work was just unsure wether it could have been a bolt on type.......i have seen some tips that i like there the same as the sri ones but bigger coz i think the sri ones are too small. also my mate has got a 07 sri and his tip it alot wider than mine did they fit different tips on older models
    Blantyre
    If your changing to the VXR tips then ideally you would want the rear diffuser , or you would need to adapt your own SRI diffuser
    http://www.vectra-c.com/forum/showthread.php?t=103711
    iver
    yeah i have got to go and get one and get it painted. na not fitting vxr tips fitting bigger sri tips mate
    argyll, scotland
    already got the vxr diffuser and vxr rear upper and lower spoilers to go on, im undecided wether the new tailpipes will be welded or clamped on will see on wednesday how much is left as i have the full system from the 2.2 to have a play with and see what looks best .
    will let you know how i get on and possibly post up some etch a sketch, cave paintings or possibly an actual picture
    iver
    lol yeah mate sounds good, have you got your stuff painted
    argyll, scotland
    nah not yet, doing the insert myself as its going ford graphite grey (my car is black) to match the bootstrip i painted but having all the kit done by the pros. just need to get a quote for it all, my vxr tips are slightly larger than the standards so ill have to make the exhaust holes slightly bigger i think
    iver
    o rite have you already got a twin exhasut then and just changing the tips
  1. Changing Front Wiper Motor Tips?
    By Kev_G in forum Vectra C / Signum Troubleshooting
    Last Post: 25th July 2011, 10:36
  2. MIJ Exhaust Tips
    By Aidi in forum Styling
    Last Post: 22nd January 2011, 11:43
  3. Changing rear brakes tomorrow, any tips?
    By SRI456 in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2010, 23:53
  4. any tips on how to cut the rear valance to show my exhaust tips
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 18:58
  5. Exhaust tips
    By ZC_74 in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2007, 03:49
