Results 1 to 10 of 26
Thread: condensor replacement
    North East
    Default condensor replacement
    Done this on my last vectra B with no problems. Took off front bumber and slam panel and that was it. Does anyone know if its the same for my new vectra C? got a new condensor in the post.
    Lee
    North East
    anyone with air con knowledge?
    salisbury
    just changed mine on a 2006 signum which i think is the same a vec-c front what do you need to know.
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    think mine needs changing as the air con was re gassed 3/4 weeks ago and it gurgling already and not as cold
    is it easy to change i was under the impression the air con gas was dangerous and not to be played with?
    is there a way of de gassing it safley fitting unit and taking to get re gassed again?
    ids1973 i changed the rad on mine and yes its slam panel then condenser looks very easy to do
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    remove the font bumper thats all then its right there for you
    salisbury
    Default condenser pic
    Attachment 32526lee, as promised picture of condenser with fixing bolt locations circled in blue and o ring location in red.
    ps the pic is of the knackered condenser!
    Regular Member um20's Avatar
    Mar 2007
    Doncaster
    I'll hijack this thread if I may - for those of you who have replaced the condenser did you ever do a DIY pressure test?
    Reason I ask is that our aircon leaks, it was filled up a few months ago and 2-3 weeks later it was back to empty again. It's getting warmer, so I need to sort it out, so I've had the bumper off today and carefully loosened the condenser seals and there was a 1 second "pfffft" of the residual gas escaping and then nothing. I took the condenser off, put my thumb over 1 hole and stuck a small funnel in the other. I blew in the funnel as strong as I could and the air was going nowhere. Take my thumb off, air comes out. Stop blowing, air comes back.
    I'm guessing either the leaks are so minute they only appear under the high pressure of a sealed system, or the condenser isn't the part leaking.
    Just wondering if anyone has any thoughts?
    It also appears that my 1.9CDTi 06 doesn't have the version with a drier, which makes it cheaper, but it's still going to be a £90 punt to see if it's the condenser at fault.
    salisbury
    um20, when i loosened the connectors on my one it also hissed but the amount of gas was minimal. the best thing you can do is get some flora dye (think thats what they call it) put in and check with a uv light and any leaks will glow green. my rad looked like it was radioactive! i have seen this in a diy can that you can put in yourself but can't remember where, but any aircon guy will be able to do it.
    As a note prior to changing my condenser it held a vacum!!!! even though it was knackered, figure that one out.
    The dryer is not attached to the condenser but is behind the rad bottom left, i didnt replace mine as tested ok.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I replaced my intercooler and i put it up ramps so i didn't have to remove spam panel and aircon rad. Not sure weather this might be beneficial for just doing the aircon???
    Mar 2007
    Doncaster
    Quote Originally Posted by Dougb View Post
    Thanks Doubg, that's what I was hoping to hear! I've ordered a new condenser, I assume that it leaks under the pressure (hence why there's residual gas once the pressure gets too low) and my puffing isn't enough to duplicate it. Our existing one certainly looks knackered, stones all over the place. I might even do a How2 on it, it seems a common problem and the facelift bumper removal is different to the existing bumper removal in the How2 section.
  1. Air Con Condensor
    By iain.condliffe in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2011, 20:08
  2. Would You Say Condensor?
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 21:41
  3. air con condensor
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2011, 12:04
  4. Air-con condensor..
    By tonyo in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2011, 21:28
  5. Air Con Condensor Help!!
    By Jimooo in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2010, 22:34
change vectra c condenser
