Results 1 to 10 of 18
Thread: Anyone Fitted Bilstein B4's to a Vec SRI/Signum Design?
    Wales
    Default Anyone Fitted Bilstein B4's to a Vec SRI/Signum Design?
    Just dorve a new Astra SRI and the ride is great - firm but compliant over the bumps. Much less 'crashy' than the Signum Design (which is like a Vec SRI).
    Anyone fitted B4's to a vec SRI/Signum Design (NOT a std Vec). Wondering if it would help reduce the slightly harsh/crashy ride ride?
    Thanks in advance
    Regular Member david.aka.judas's Avatar
    Suffolk
    I think the sri and std vecs have the same dampers, isn't it just in the springs?
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Quote Originally Posted by Judas View Post
    Don't think so, my vec needed a rear shock for mot 2 months ago and I was told it was an sri shock, therefore much dearer.
    Suffolk
    okay - I must admit I wasn't overly sure.
    how about emailing bilstein.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    SRI/normal shocks are the same.. and Bilstein B4 is a direct replacement for both..
    Regular Member crespo's Avatar
    Bournemouth
    Im pretty sure SRI suspension is the same as standard but the springs are 15mil lower.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    i have been told the shocks are different between the sri and a standard vec and that the sri ones are virtually the same as bilstein b4's
    Sep 2009
    Fife
    Trim : M Sport
    Engine : 3.0 TT
    So what you're saying is that I got bent over a table at MOT time...?
    Cambridgeshire
    SRi shocks are shorter than standard ones to cope with the shorther (15mm) springs. The B4's are a direct replacement for the SRi shocks, however, because they are made by Bilstein they will last longer and wear better
    Wales
    Guys,
    Everyones input is appreciated but my question has got a bit er, lost.
    Do B4's makes the ride less 'crashy'?
  1. Just fitted Bilstein B4's and Eibach Pro Springs
    By higgy1541 in forum Handling & Braking
    Last Post: 1st October 2011, 19:31
  2. Bilstein b4's
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2010, 12:05
  3. Eibach Pro and Bilstein B4's
    By MattW in forum Handling & Braking
    Last Post: 18th March 2009, 10:26
  4. Bilstein B4's on an SRI
    By Ben999 in forum Handling & Braking
    Last Post: 9th March 2009, 22:45
