when it's hot in the cabin due to outside temperature I'm noticiing that on first press of the throttle pedal that it clicks as if it's sticking momentarily, which you can also feel through the foot, but will only do it the once , seems like something is sticking due to expansion, is this just a case of lubrication on a spring around the pedal area perhaps or something a bit more sinister that occurs with these? want to get down under there for a look but trouble with joints at the moment , which are restricting me a bit, annoyingly so!
Cheers Pete
