Thread: clutch release bearing
    Regular Member martin_SRI's Avatar
    Nov 2009
    Billingham, Stockton on Tees
    Default clutch release bearing
    Recently noticed when i put clutch pedal down there is a vibrating sound, and i can feel it through the pedal also. Am i right in thinking it could be the release bearing? If so how much would i be looking at to get a new one fitted?
    Aldermaston (Berks)
    I also have this vibrating through my clutch pedal, hope its not the dreaded dmf.
    wooler
    i have also got the vibrating and the reli loud rattle when the clutch bites, its deff the thrust bearing ( release bearing) new clutch kit will sort that out, but am not sure if your ment 2 replace the dual mass flywheel aswel when you change the clutch
    Regular Member pugs,signum's Avatar
    swansea
    It is recommended that a new dmf is fitted when a new clutch is fitted and vice versa! just like changing your drake discs you'd change you pads too.
    If you need a new release bearing then the gear box will need taking out so probably be worth of replacing everything while its apart!
    PRESTON
    if there is a loud rattle when the clutch is up, it's more than likely the DMF failing not the release bearing, sorry,,,,,,,,
    Regular Member recoveryman's Avatar
    glasgow
    Vehicle : vectra
    Trim : elite
    Engine : 1.8 petrol
    Mileage : 92000
    i have a loud rattle when i press my clutch pedal just 2-3 mm i thought for a minute it was moving the crankshaft but i have ruled that out there is no vibrating through the peddle and i didnt think the vectra c had release bearing as such i thought because it is hydraulic it was just a slave please help its doin my head in i only get the rattle when i press clutch peddle down its normal when peddle up
    Last edited by recoveryman; 31st May 2010 at 12:38. Reason: forgot to add something
    swansea
    Quote Originally Posted by recoveryman View Post
    Sounds like the dmf (dual mass flywheel) mate, i have exactly the same problem and got my car booked in to do the dmf and clutch next week!
    just quick quesion?
    does yours rattle when you rev the car and when the revs drop back to 1000rpm? also make the odd clunking noise while its ticking over just from time to time? aslo the sound should be coming from gearbox erea.
    What engine have you got? 1.9cdti?
    mine does this but no one mentions these symptoms
    Im just hoping that mine is the dmf as its going to cost a hell of a lot to get it done n il be fumeing if it dont fix it
    glasgow
    Vehicle : vectra
    Trim : elite
    Engine : 1.8 petrol
    Mileage : 92000
    i dont even need to rev the car i can be sitting at idle speed and i just have to depress clutch 2 or 3 mm down and it starts rattling my car is vectra elite 1.8 petrol on a 53 plate never had a bit of bother untill now 75k on the clock car still drives and changes gears like a dream its just annoying me now it reminds me of being a kid and putting a clothes peg and card on the spokes of the wheels to make it sound good lol cause thats exactly how it sounds
    Southport
    Anyone any ideas how long the clutch will last with the thrust bearing noise? My clutch is working fine at the moment ive just got the bearing noise on the point of bite.
    CDTi 150 SRi 06reg 104k
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    How long is a piece of string scott,it's a thrust bearing that is pre packed with grease,depends how long before it siezes up, if it doe's it will wear through the clutch release plate,
    so the answer is no one can tell without removing gearbox.
  1. DMF or Release bearing.. please confirm
    By jamesb in forum Engine & Drivetrain
    Last Post: 8th September 2012, 13:12
  2. Clutch Thrust Release Bearing Perhaps.?
    By sootyville in forum Engine & Drivetrain
    Last Post: 24th July 2011, 07:58
  3. clutch release bearing
    By pizzajazz in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 17:36
  4. Clutch release bearing help 3.2 GSi
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 29th June 2009, 10:52
vectra c clutch release bearing
vectra c release bearing
vectra c cdti faulty release bearing
vauxhall vectra clutch release bearing
vectra c release bearing bolt size
vauxhall vectra c clutch thrust
2009 vauxhall zafira 1.9cdti clutch release bearing bolts
vauxhall zafira noisy clutch bearing
vectra clutch release bearing how long will it last
2008 1.9 cdti 120bhp vectra c release bearing
2005 vectra clutch release bearing
changing clutch frust bearing vectra c
vectra 1.8 throwout bearing
Vectra c 1.9cdti 150bhp thrust bearing gone
vectra c gearbox thrust
https:www.vectra-c.comforumshowthread.php111188-clutch-release-bearing
fitting a vectra sri clutch
Clutch bearing vectra sri 150
opel vectra b release bearing problems
opel vectra B release bearing problem
buy clutch release bearing vauxhall vectra
vectra sri clutch release bearing
thrust bearing clutch vectra
Can clutch bearing cause pedal to drop on a vectra
vectra c z20net clutch release bearing
