Results 1 to 10 of 18
Thread: air con not going cold
    Enfield
    Default air con not going cold
    Looking for some advice. My 56 reg Vauxhall Vectra 1.9 diesel air con is not working. I turn it on and the indicator light goes yellow/amber, however, it does not go cold. Do I need a re-gas or is it more serious.
    Regular Member crespo's Avatar
    Bournemouth
    Re gass or you may have a leak. only one way to find out.
    Take it to quikfit as it is only £25 to get it charged and if you have a leak and they cant do it they dont charge you.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Assuming you used the aircon reasonably regularly before this point, the best bet is that the condenser has taken damage and the refridgerant gas has leaked.
    You could take it for a 'no cold, no charge' regas... it may work.... it may also be lousy again a couple of weeks later.
    If it were me I'd change the condenser and receiver/drier and then get it checked/regassed. Condenser with R?D is commonly between £100 and £130 from a generic supplier.... you labour is free and the check/regass is £25-£40 offers depending.
    Sep 2009
    Glasgow
    £25 my local kwik fit is charging £50
    Bournemouth
    Quote Originally Posted by Handyandy-UK View Post
    Personaly i would pay £25 to see if it has a leak before i changed anything. Nothing worse than throwing over £100 away.
    I wouldnt change my engine if it was not working propperly, I would get it checked first.
    Bournemouth
    Quote Originally Posted by nokiaman1978 View Post
    Its on offer at the mo.
    Enfield
    My local kwik fit said 49 pounds not 25 pounds. Where is this offer?
    Bournemouth
    Quote Originally Posted by droid1978 View Post
    Bournemouth. A bit far for you mate. I thought it was nationwide. Shop around. You should be able to get it done cheaper than that.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It was on offer at all of them but the offer has ended. TBH i'd go to Kwik-fit first as the computer they have does all of the work. An un-trained monkey could use it (just as well lol)
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I have the same problem at the minute and I think its down to lack of use as I hardly used it really as it causes the car to burn more fuel and at current prices I tend to just open the window.
    I have booked the car into MPG at Middlewich for a regas and its costing £45 and I am only having it done because we are going away in the car and the dog is coming so my best mate must stay cool
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  3. So you think it is cold here.
    By ed taylor in forum General Chat
    Last Post: 23rd December 2009, 15:36
  4. No Cold Air
    By dhwigston in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2009, 18:52
  5. A cold one.
    By shan in forum General Chat
    Last Post: 10th September 2007, 00:40
