Thread: glow plug fault?
    Regular Member wilbur1's Avatar
    wrexham
    Default glow plug fault?
    Can anyone please help i've got a vectra 1.9 cdti sri (56) plate when i start the car from cold the management light comes on then it goes off after a few minutes and stays off the car runs perfect, i had it plugged in and it comes up glow plug fault i;ve changed the relay and glow plugs but no change any ideas please.
    Sep 2009
    north wales
    Mine does exactly the same and has done ever since alternator failed and was replaced. I doubt if you needed to replace glowplugs, did you have any other faults with the car before the spanner light came on. Talking to my mechanic apparently this also happens on Renaults and some other cars he has come across. It has been said on this forum that if you disconnect battery for an hour it clears the light but that has not worked on mine.
    wrexham
    Thats when the fault came mate when i got the alternator changed. i had the fault cleared twice but still comes up glow plug fault when its plugged in. i've wasted my time and money by the looks of it. its got to be linked to the alternator somehow then. if i find out i'll let u know mate and u do the same if u find out.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Will keep an eye on this, as a mate has exactly the same issue following his alternator change.
    Aug 2009
    herts
    and,......me too! after alternator change
  1. Spanner light glow plug fault
    By drewdrewuk in forum Engine & Drivetrain
    Last Post: 25th January 2013, 12:53
  2. Glow plug fault
    By Jekyll & Hyde in forum Engine & Drivetrain
    Last Post: 19th May 2011, 22:27
  3. glow plug general fault.
    By woodspsx1 in forum Engine & Drivetrain
    Last Post: 7th April 2011, 07:53
  4. Glow plug removal + elec fault
    By mr.c72 in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2010, 22:23
  5. 2.0 dti glow plug fault???
    By 3.0cdti-taxi in forum Engine & Drivetrain
    Last Post: 16th May 2009, 09:24
