Results 1 to 3 of 3
Thread: Vectra fault codes
    shropshire
    Default Vectra fault codes
    Hi
    Hope someone can clarify an issue for me. Father in law has a Vectra with z18xe engine, actually a very late veccy b, but think same engine was used in early veccy c's and zafiras.
    EM light has come on, reading P0136, P155, and P0176. He's changed the pre cat lambda, and the EM light has gone out, but the Emissions light has come on. Hasn't had codes read since.
    The car had the ECU repaired about 14 months ago, dry joint on earths issue, but i don't think this is relevant.
    Looking at the codes this seems to suggest it's most likely to be a bad post cat lambda, rather than the pre cat one he has changed. Could anyone advise ?
    Thanks Paul - PS my wife has a black 57 plate Vectra SRI, truly brilliant car !
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Faulty air flow meters cause incorrect lambda sensor reading which give the fault codes relating to lambda issue, which people then change when they are not faulty..
    shropshire
    Thanks Alanv6. But would like to just confirm 100% that P0136 is the post cat lambda. He's got someoine fitting s/h pre cat lamdas which I really don't think relates to the problem, and can be creating problems and expense that he doesn't need - Thanks Paul
  1. Replies: 1
    Last Post: 9th September 2012, 17:53
  2. fault codes vectra c turbo
    By davedave in forum Petrol Engine related
    Last Post: 29th June 2012, 13:22
  3. anyone no how to get the fault codes up on a vectra c
    Last Post: 17th May 2012, 20:04
  4. Vectra c Y22DTR fault codes
    By delboy2028 in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2011, 00:57
  5. Two Fault Codes Vectra C 3.2 Auto
    By tedsy in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 15:03
