Thread: coolant tank sludge
    Nov 2009
    Luton
    Default coolant tank sludge
    hi all, just a quicky, found some sludge like what you get under the oil cap in my coolant tank, now im thinking its just where its been stood up as ive been using my run around, ive heard of oil cooler problems but thats for certain transmissions, any thoughts?
    Regular Member E5CDW's Avatar
    Ashby, Leicestershire
    could be just where its beenn stood, flush the system out, use the car, if it reappears then you know you have oil leaking into the water somewhere. (oil cooler, head gasket ect).
    If your not sure how to flush the system, get back to me and ill talk you through it.
    Regular Member Exclusive BV's Avatar
    West Midlands
    what colour is it?
    Whats the gravity like in the coolant?
    Have you checked the oil for water contamination?
    As a 2003 the radiator might be starting to break up
    I know my local mechanic is starting to see a lot more of these than normal, the last winter damaged quite a lot of radiators / coolant systems, all found to have insufficient coolant strength
  1. Replies: 1
    Last Post: 4th May 2011, 20:36
  2. replace coolant tank.
    By frasedeb in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2011, 11:03
  3. coolant tank cap
    By melvin in forum Engine & Drivetrain
    Last Post: 4th December 2010, 00:05
  4. Coolant tank
    By John2360 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 14:09
  5. Sediments in coolant tank
    By haegwani in forum Engine & Drivetrain
    Last Post: 7th October 2007, 17:13
