Results 1 to 10 of 14
Thread: little power 150 cdti
    Regular Member smokydiesel's Avatar
    barnsley
    Default little power 150 cdti
    hi to all i hope you can help me my car
    i was driving up the motorway when it through a fit the engine management light came on so i drove to my brothers and we cleared the code 2279 (egr valve leak) so i checked the egr and cleaned it out while i was at it then not used it for a couple of days
    when i used it today the dreaded light back on same code and no power it takes ages for the car to build speed up it will rev when stood but slowly
    i checked the egr for leaks with carb cleaner and no leaks
    but the car has no power at all foot to the floor and it takes ages
    what will happen if i take the egr of and put the blanking plates on
    need help as its just a big pain
    cheers for any help
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    best off blanking egr off altogether with a coke can cut out a templte with 4 holes for the bolts then sandwitch it inbetween the egr outlet and manifold then run the car if it runs good you will have a engine managment light on then its def the egr thats goosed hope this helps
    barnsley
    hi thanks for that i have made myself the blanking plates for the egr and exhaust pipe not going to pay £42 at regal but will this cause any running probs?
    i will be getting it mapped out later but need it up and running cheers for any more info
    kings lynn, norfolk
    will cause no probs mate will make your car run better only problem you will have is the engine managment light on if you totaly blank it but performance will not be effected once remapped out the light will be off too
    hope this helps
    barnsley
    right in that case i will try that tomorrow then i can live with the light on for about a week tho till it's mapped out just hope there's no major running probs but thanks for the help
    barnsley
    a bit of a update replaced the egr valve with the blanking plates and still little turbo boost the car is going on the diagnostics tomorrow so i should find out whats wrong hopefully so should have more info i have also cleaned the boost sensor and that didn't make any difference
    kings lynn, norfolk
    Have you checked your vacuum boost pipes the sticky thread at the top on here if you have a minute hole in any one of them you will loose all boost mate worth checking all pics are in the thread it's the cdti check your boost pipes sticky worth a read and check or even replace them any way as I found great improvements mate if that fails could be a hole in your intercooler or turbo pipes if it's just boost your losing and nothing else
    barnsley
    hi yes checked my boost pipes and the intercooler and pipes just don't know but should have more answers tomorrow cheers for the help tho
    barnsley
    well good news turned out to be a blocked air mass meter new one fitted from auto vaux £78 and a hour at the garage to find the prob just need to get the egr valve mapped out now and job done
    we have the power
    kings lynn, norfolk
    Good to hear mate yeah get rid of the egr and also vent your oil breather to atmosphere and get rid of
    all the oil an sludge and hot smoke from going into your engine
  1. No power from 1.9 cdti 150
    By garetmcc79 in forum Engine & Drivetrain
    Last Post: 1st April 2012, 08:04
  2. 1.9 cdti 150 no power
    By baz_cdti_sri_150 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 15:00
  3. 150 cdti with no power
    By pauly in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 00:23
  4. 150 Cdti down on power??
    By shrekster in forum Engine & Drivetrain
    Last Post: 7th December 2008, 00:19
  5. V6 CDTi - How much power?
    By Craig Rogers in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2008, 20:31
