Results 1 to 10 of 16
Thread: Air Con Condensor Help!!
    Nov 2009
    Wakefield
    Default Air Con Condensor Help!!
    Hi all,
    Just taken 56 plate 1.9cdti to Kwik Fit and he tells me the condensor has packed in, it was spraying his gas all over the front of the car ha ha.
    Now i know there quote and vaux is rediculous, however done some research on the site and found autoairconparts that sell them at a good cost, question is, he mentioned a drier i think or something i would need or something?
    Is this true? Any advice/ help would be appreciated,
    Thanks in advance
    James
    london
    the receiver/dryer is the cylinder on the side of the condensor. this should always be replaced after any leak or compressor failure. some sort of filter inside and something to absorb the moisture in the system. once the system has a leak it absorbs all the moisture from the atmosphere and blocks up making system run at too high pressure.
    Nov 2009
    Wakefield
    Hi, thanks for the info. Anyone know elsewhere to get parts??
    Thanks all.
    PRESTON
    The Vauxhall one comes with the dryer attached, part number 13114943, for all 1.9CDTI's. Most of the aftermarket ones dont, hence the price variance. the dryer can be bought from Vauxhall seperatley too, under part number 13115040. might be worth pricing this and see if it works out cheaper using this with a non gen condenser
    Nov 2009
    Wakefield
    Ah right will do thanks alot. seen on that website i mentioned earlier there is an aftermarket if u like condensor for £86 and then the drier is about £34. You think these would be ok? They have 18 onth warranty, prob not worth anything i know lol
    Thanks alot
    James
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Looks like this is the one you're after.... R/D already fitted.
    http://www.autoairconparts.co.uk/Car...t-16-6514.html
    Regular Member Bethan39's Avatar
    South Wales
    Sorry to hijack the thread i understand it's £49 for a recharge and they guarantee to be colder when you leave do you still have to pay even though you have a leak thanks again
    Nov 2009
    Wakefield
    ah wicked thanks for that, it doesnt say it has in the name or descriptions does it? Hopeit does come on it haha
    Thanks again!!
    PRESTON
    excellent price handyandy, will bookmark that page incase i need one in the future.
    Jan 2010
    Sheffield
    £125 from autovaux for air con rad trade. 1 hr tops to fit . Did mine today .
  1. Air Con Condensor
    By iain.condliffe in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2011, 20:08
  2. Would You Say Condensor?
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 21:41
  3. Air con condensor fubar
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2011, 10:34
  4. air con condensor
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2011, 12:04
  5. Air-con condensor..
    By tonyo in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2011, 21:28
