Thread: V6 cdti ?
    Regular Member E5CDW's Avatar
    Ashby, Leicestershire
    Default V6 cdti ?
    hi all,
    Iam new here and looking to buy a vectra c 3.0 cdti, iam looking to find out which is the better engine ? the 177 BHP or the 184 BHP ? is one more reliable than the other ?
    Also, any other information on the v6 would be nice.
    Thanks in advance for and help,
    Chris
    Only time will tell whether one is more reliable than the other
    Last year virtually no reports of problems, then owners of the Y30DT (177 PS) started reporting a problem which was traced to blocked SCV
    The Z30DT (184 PS) should have the later SCV so should not suffer this
    However, the Z30DT is typically fitted with a DPF so consumes more fuel during the regeneration cycle
    The engine is manufacturered by Isuzu, which means some dealerships don't have a clue about it
    Other issues can be solenoids, etc. which are common faults with high pressure diesel engines
    My Y30DT has had the original SCV replaced under warranty and that has been the only engine fault
    All the other issues have been standard in common with the Vectra; switches, suspension, brakes
    I've heard reports of the later engine z30dt having swirl valves is this the case ?
    All diesels have swirl valves and as with all parts they will eventually fail
    I'm not aware of this being a major issue on the 3.0 V6 CDTI though, it seems to be more of an issue on the smaller engines
    ok thanks, ive found a nice black one, 28500 miles on a 56 plate, anything to check for when i go to have a look ?
    Again, Thanks for you help
    Just the usual VX weak points;
    suspension, steering, electrics
    Look at the front tyres, outside shoulder wear is quite normal
    Look at the rear tyres, inside shoulder wear is quite normal if the tryes have not been rotated, either as they wear or at renewal
    They may be either 215/50R17 or 225/45R17, but they need to be at least 91W and ideally at least 94W (XL)
    Check ALL the electrics
    The service schedule will be 20K miles / 2 years as it should have a Z30DT engine, so make sure the service book shows at least one service at about 2008 / 15K miles
    The oil level should be checked with the engine slightly warm
    Ideally, put the car through a MoT or at least have the suspension and steering fully inspected
    When you take ownership put the car through a Hunters 4 wheel alignment
    Not cheap at between £60 and £80, but that will make sure the camber and toe are correct, as all too often it is not and this rapidly destroys the tyres on the Vectra C
    Iam an automotive technician so i can check the 4 wheel aligment at work, thanks for the heads up on the service intervals.
  1. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  2. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
  3. CRD2 Tuning Box for V6 CDTi or 1.9 CDTi
    By The Doc in forum Parts for sale
    Last Post: 20th October 2006, 21:51
