Thread: Brake pad life
    Sodding Typical on Sea
    Default Brake pad life
    What would be a decent life span of brake pads my car is on the original GM pads and they are about 3/4mm left with 19K miles done, is this about right?
    Depends on how much they are used. Everyone drives differently.
    Does approx 20K sound realisatic one way or another though?
    15 months / 19K miles
    Seems quite fair if those are the front and rear pads
    You can make them last up to 2 years / 30K miles on a 1.8, and as little as 6 months / 10K miles on a automatic
    The Corsa we have goes through front pads every 5K miles
    I normally replace discs at every second brake pad change, but my warranty didn't pay for the discs unless the dealership put in the report
    I managed to get three sets of front pads to each set of discs, but the rears would only manage two
    Once the first set of rear pads and discs were changed the replacements lasted much longer, and that has been the same on every Vectra I have owned
    Rears still have about 4mm the fronts are 2>3mm so seems reasonable to me then. Time to seek out new ones
    Regular Member Marc 100's Avatar
    Nov 2005
    Berks
    Front discs and pads changed at 40k, rear discs and pads at 45k. Used the dealer service kit both times. Everything needed changing again at 84k recently. Car is a 2.0T.
    Apr 2008
    High Wycombe
    Vehicle : Vauxhall Insignia
    Trim : SRI NAV
    Engine : 2.0 CDTI 140
    Mileage : 20000
    I've a 1.9CDTi Signum Design and mine are on the originals and I'm on 91k.
    May 2007
    South Oxfordshire
    Had my V6 CDTI (auto) serviced at 46K miles - 6 years old and still on original pads and discs. Was told there was still 25% left on all pads, so left it alone. Anyone beat that?
    My old V6 cdti was on 67k with the oe pads and disks.
    I changed them out today pads only, discs will get done at next time, one pad the n/s outer had about 2.5mm the others 4mm they were the originals.
    I fitted a decent quality replacement set and bed them in with copper grease, cleaned the sliders etc,
    Finally repainted the minor damage to the spring clip and such and had a wee drive to bed them.
    All's good so far and the next stage will be to clean down and paint the wishbones and rear susp' arms.
  2. Brake pad life
    By Derek Mc in forum Suspension, Wheels & Brakes
    Last Post: 11th December 2011, 19:41
  3. Brake pad life
    By fishphone in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 22:38
  4. i saved the life of a life gaurd:)
    By the fisherman in forum General Chat
    Last Post: 26th September 2010, 21:25
  5. Brake pad life
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2007, 14:52
