Thread: A bit of advice on ride height
    Regular Member chrisf70's Avatar
    Mar 2007
    Cambridgeshire
    Default A bit of advice on ride height
    Evening, my o/s front spring broke on my 2.2 Direct Signum Design. I took it to a local Saab independent specialist and they replaced the two front springs today, just the springs not the dampers. All good, but got the car home and was looking at it in the drive and it looks really high at the front, 4x4ish!
    Had a look on the invoice for the work and the part number is 93190520 which looking on the parts listings here, http://www.vvon.co.uk/forum/vectra-c...rs-prices.html , seems to be the right part. Each listing for that code number says the engine size/number and either hatch/saloon/estate and most importantly lowered sports chassis which the Signum Design has.
    So why is it sitting so high? I've mesured the gap between the top of the tyre and the wheelarch lip and it is around 80-90mm. Will they settle down in time, but I'm sure they'll need to settle around 50mm which is a lot, or are they probably the wrong spring, or because they are new springs on 50,000 mile dampers they are too springy for the dampers!?
    Could someone help, as I'm going to have to go back to the garage tomorrow morning otherwise as I'm not HP with it. Thanks. Chris.
    PRESTON
    i just checked Vauxhall EPC and 93190520 is listed as the correct springs for a Signum with lowered sport chassis, but i also checked my Veccy estate, which does not have lowered suspension and she sits at about 85 mm between tyre and wheelarch lip, maybe the springs were wrong to part number or the garage got them from the factors and booked them out under Vauxhall part number. Problem is that the factors do not supply springs for lowered suspension and they are way cheaper than genuine Vauxhall. looks like a trip back :-(
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Maby your car was lowerd before... i have from earth to the top of wheelarch.. about 69cm with new SRI springs on mine..
    Mar 2007
    Cambridgeshire
    Cheers, think I'll have to have a ride back out to see them tomorrow. I know reading in the past that when people put lowering kits (springs and dampers) on cars it can take a while to settle down to the correct ride height, but I just think this is too high. You can see the spring and damper in the wheel arch, where you couldn't before.
    PRESTON
    just nipped out and measured from earth to the top of wheelarch and its 71cm front and rear, so sorry to say it looks like they somehow fitted the standard springs, i dont think they will settle by 20mm, which i believe is about the difference between standard and sport suspension.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The shocks wont affect the ride height mate, they hold no weight at all, all they do is slow the movement down.
    Mar 2007
    Cambridgeshire
    Wonder what joy I'll get trying to get them to change them!
    Barney, you say that motor factors don't supply the sports springs?
  1. ride height
    By pidge in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2010, 17:59
  2. SRI ride height ??
    By Mickyboy in forum Suspension, Wheels & Brakes
    Last Post: 18th March 2010, 12:05
  3. Ride Height
    By paulhb in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2009, 10:28
  4. GSi ride height
    By gtr1000 in forum Suspension, Wheels & Brakes
    Last Post: 9th February 2008, 18:21
  5. Ride height
    By janc in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2007, 22:13
