Thread: key in ignition live module
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Default key in ignition live module
    Does any one have or have seen this module for ignition live with key in detection for use with aftermarket HU,
    http://www.canm8.com/products/canm8-...ed-outputs/57/
    Aug 2009
    Trim : SRI
    Mileage : 50000
    or is this what i need for aftermarket head unit,
    http://www.caraudiodirect.co.uk/ctsv...l-adaptor.html
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I would use an SOTor ISO2CAR cable to convert your wiring to fit an aftermarket head-unit.
    For the ignition live, most people take a feed from the black terminal of the ciggy lighter.
    The cable that you mention is for getting the steering wheel radio controls to work your display and your aftermarket head unit.
    The CAN interface is not really necessary and will be quite expensive.
    For your steering wheel controls, ensure you get the correct one, as they are manufacturer specific....JVC, Sony, Pioneer, Kenwood etc.
    To do it properly therefore, you will need the SOT / ISOCAR loom and the steering wheel adapter loom.
    Aug 2009
    Trim : SRI
    Mileage : 50000
    I am trying to keep the key in ignition function for powering system, this way i can use stereo without having the ignition turned on and it turns off when i take keys out just like factory unit.
    Aug 2009
    Trim : SRI
    Mileage : 50000
    Which CAn-Bus adapter do i need to get for ignition live without engine running or key in position 2?
    Aug 2009
    Trim : SRI
    Mileage : 50000
    Bump for some help.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I am sorry to say, that you are in an area, where most mortals fear to tread.
    There are some good forums in Germany and Holland that do a lot of modification work, but I don't recall seeing anything on them either.
    May be a job, where you take the mantle, and show us the way forward.
    Sorry that I could not be of any help...best thing to do is speak to companies who produce the can interfaces, like F K Murphy, or CanM8 etc.
    Aug 2009
    Trim : SRI
    Mileage : 50000
    I got my canbus module today SPAL Automotice ICB-3, this will give me an ignition live when key is inserted into ignition (KEY PRESENCE) , I just need to know one thing, how easy is it to get to the 102 pin connector behind striker panel? I need to connect the CAN HIGH line to this point.
    http://www.spalautomotive.co.uk/acat...NTERFACES.html
  1. No ignition live please help
    By foxyland in forum Vectra C / Signum Troubleshooting
    Last Post: 12th December 2012, 22:49
  2. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  3. ignition live
    By Nessy in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2012, 19:23
  4. Ignition (Spark) Module & CanBus
    By omega2498 in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2007, 10:26
  5. Ignition Live
    By leeds vectra in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2006, 01:20
