Results 1 to 3 of 3
Thread: Need advice/diagnosis re 57 plate Vectra 1.9 CDTi 150
    Swindon
    Default Need advice/diagnosis re 57 plate Vectra 1.9 CDTi 150
    Please help and advise.
    I have a Vectra 1.9 CDTi 150 which has done 73k miles.
    A month back I was driving on the motorway when the car/spanner light came on and I lost power, the battery light started flashing and I had to pull over. The car wouldn't start again, but after being towed 150 miles to my destination, it started OK, if a little juddery and I managed to drive 200 miles back home...
    Took it to a garage for a diagnostic check, and they reported that injectors 1 and 4 had an open circuit and they cleaned them for me. All ran well until last week - same/similar problem - the car/spanner light came on but this time I could restart the car and get it home (took 5 restarts though).
    The car has been back to the garage (same one) and they haven't found anything wrong, but they suspect the injectors "may" need replacing and I would have to take it to a Vauxhall dealer to get it fully diagnosed.
    The car is under a third party warranty (when I bought it second hand last year) and the place I got it from are reluctant to get a dealer to check it because they will just change the injectors and charge a fortune. I am taking it to them (in Blackburn 200 miles away) so their mechanics can take a look.
    I have checked the 3rd injector wiring issue - not that my engine has blue connectors and the engine number is new enough not to be affected.
    Is there anything else I need to check, or get them to check for me?
    Any advice would be helpful
    thanks
    Rich
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Could be EGR related.
    Lots of thread on here regarding it, you can maybe diagnose this by disconnecting it and see how it runs - but this won't always work, it depends on what the fault is (if at all) with the EGR valve.
    Swindon
    Thanks Dan,
    just been reading through the How 2 on cleaning the EGR etc - might give it a go, but a bit wary of trying...
    I'll see what they say next week and suggest that it could be EGR and get them to look. If it is, and they replace it I think I'll have a do at fitting the FIAT gasket myself...
  1. Vectra cdti 1.9 Sri 120 - 58 plate
    By allysri120 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2012, 09:20
  2. Loss of power diagnosis Vectra 1.9 CDti
    By MT82LFC in forum Engine & Drivetrain
    Last Post: 17th June 2011, 20:58
  3. Vectra CDTi Sri (150) 56 Plate
    By Phil-W- in forum Cars for sale
    Last Post: 12th February 2011, 11:30
  4. CDTI 150 Clutch noise. DIagnosis required
    By 12345 in forum Engine & Drivetrain
    Last Post: 6th May 2009, 18:35
  5. Vectra 1.9 cdti 150 problem - diagnosis?
    By Fruit'n'nut in forum Engine & Drivetrain
    Last Post: 7th March 2009, 15:28
57 plate vectra cdti 120 loosing power
