Thread: "clunk" noise when taking foot off brakes
    Regular Member sdnatlst's Avatar
    Nov 2009
    Cambridgeshire
    Default "clunk" noise when taking foot off brakes
    Hi guys,
    When i brake, reasonably hard...as im taking my foot off the brake pedal, a rather loud "clunk" comes from the front drivers side wheel area.
    It doesnt do it when stationary, only when travelling along the road.
    Has anyone got any ideas what this could be? its literally when the brake pedal is about half way back up again.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    May be a ball joint. What sort of clunk?
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by Ian-Highlander View Post
    "Clunk-click every trip" ?
    Regular Member si_sri's Avatar
    Nov 2009
    TELFORD
    hi,
    the last few weeks I also had a metallic clunk sound....
    stripped down nearside front and eventually found the culprit to be a slightly weak / loose spring clip on the caliper (the one that retains the pad / holding the floating part of the caliper in place)
    ....bent the spring slightly to make the fit tighter on the caliper when in position and hey presto - no clunk. If the spring clips are weak the caliper can actually move when it bights the disc and it can knock against the disc itself
    Worth checking my friend...?
    I am after a part number for the little spring clip if any body nows, &
    how much ?
    I am going to replace both sides when I get some new ones
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    had a similar thing on a nissan primera hire car we had at work a few years ago, just as you were coming to a stop with your foot on the brake pedal, you could feel & hear the 'twang' which was coming from the front. the hire companies mechanics had a look & couldnt find anything wrong, neither did the nissan dealers.
    as it was a hire car they replaced it, strangely with a vectra c diesel, never did find out what was causing the 'twang'. typically the replacement vectra then developed a fault, engine management light came on & lack/loss of power. had to pull over & turn the engine off, wait a couple of minutes, then set off again. used to happen a couple of times on our journeys, that was then replaced with another vectra, thankfully with no faults!
    Nov 2009
    Cambridgeshire
    Its just like the pad getting stuck on the disc and taking a milisecond to pull itself off, like a metallic metal clunk noise.
  1. Replies: 7
    Last Post: 14th December 2012, 01:12
  2. whistling noise when taking foot of the accelerator
    By ballogie in forum Engine & Drivetrain
    Last Post: 23rd October 2010, 00:29
  3. Clinking noise around 2000 revs after taking foot off accelerator
    By ChrisM in forum Vectra C / Signum Troubleshooting
    Last Post: 8th November 2009, 19:36
  4. Spring "clunk/twang"
    By jasone in forum Handling & Braking
    Last Post: 1st September 2009, 13:33
  5. handbrake " CLUNK" how many clicks before ur brake holds?
    By Craig1985 in forum Suspension, Wheels & Brakes
    Last Post: 7th January 2008, 20:57
clunking noise when taking foot off brake
Clunk noise when taking foot of brake
clunk when taking foot off brake
back break makes a clunk when i take my foot off the brake
thump when when taking foot off brake in automatic
vectra c brake clonks when i brake
loud clunk when taking foot off break
when i taking foot off brake thump
vectra c brake knock when driving
clunk when set off and brake
vectra c breaks clunking
vectra c clunk when braking hard
vectra cdti clunk under feet
clunking when braking from back of vectra
clunking noise when braking hard vauxhall astra
vectra braking noise when accelerate off and break
c vectra clunking when braking
vauxhall vectra brake noise
clunk noise when foot off accelerator
https:www.vectra-c.comforumshowthread.php111033-quot-clunk-quot-noise-when-taking-foot-off-brakes
clunking sound when braking vectra c www.vectra-c.com
