Thread: outside temperature sensor
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    Default outside temperature sensor
    can anyone tell me were the temperature sensor is on my car .as it says its 42 degrees all the time hot or cold.its a 2002 1.8 16v vectra.cheers luke .
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    It's behind the front bumper mate.
    Aug 2009
    cheers mate .sorry to be dumb but do you no what it looks like and how much thay r. cheers
    Northampton, UK
    Its a small black circle thing about the size of a 2p coin in width, if I remember. You'll see it as you look at the front of the car, normally lower middle grill section, if not, just look under the bumper, or down in front of the radiator and follow the loom if you cant see it straight a way.
    Aug 2009
    found it .cheers for your help mate. luke
    Regular Member dervb's Avatar
    Jun 2007
    Thornton merseyside
    With ref: outside temperature sensor,do the boffins amongst us know.....when this sensor picks up the xtreme cold, does this in turn ,switch on the diesel fuel filter heater ,which is connected to the top of the filter.....
    Q. WHAT TEMP DOES IT BECOME ACTIVE/INACTIVE.
    Q. WHAT TEMP DOES THE HEATER REACH AND IS IT CYCLIC.
    COME ON BOYZ Thinking caps on pls......
    WGAF#5
    Quote Originally Posted by dervb View Post
    Jun 2007
    Thornton merseyside
    sorry boyz.....
    Full Member Robsey's Avatar
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    I am going to make an assumption.
    For the most part, the temperature sensor in the front bumper / grille is purely for the temperature gauge.
    The real temperature controlled functions are affected by the Coolant Temperature Sensor, which is screwed into somewhere in the cylinder head - (thermostat housing or waterpump housing). The CTS will feedback all info to the CAN system. The CAN system will then control any necessary devices (add-on heaters etc).
    Regarding actual active range for the diesel heater...I shall hand that part to someone else, as I don't know.
  1. Outside temperature sensor gone mad!
    By devore in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2013, 16:58
  2. Outside air temperature sensor
    By Pjuk in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2008, 13:31
  3. Outside Temperature Sensor
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2008, 10:59
  4. outside temperature sensor
    By billyyoung in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2008, 17:23
  5. Outside Temperature Sensor U/s
    By turnerk in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2007, 22:05
vectra c outside temperature sensor
