Results 1 to 10 of 20
Thread: Need a speedy reply wife pregnant and having contractions since 2000
    Regular Member stuart813's Avatar
    gosport
    Default Need a speedy reply wife pregnant and having contractions since 2000
    Hi i'm still having problems with my 1.9cdti 150 keeps juddering. I have just recleaned the EGR valve and boost sensor. I also did the air box mod while i was at it.
    Went to start the car after and it wouldn't start. i did leave to pipe from the air box off and the one from the inlet manifold. Once i put these back on it stared but was running lumpy (could of been the carb cleaner) then it stared to run a bit better but still juddery.
    So i removed the injector plugs to see it that was the cause but no so i the disconected the boost valve, no change so i then disconected the EGR and it cured the problem.
    My questions are:
    1. Will running the car with the EGR Valve disconnected cause and damage to the engine?
    2. Where can i get a blanking plate for the EGR and what fiat gasket is it that everyone is going on about??
    Northampton
    Engine : A20DTH
    Mileage : 88000
    No it will not damage the engine.
    A wild guess says Fiat can supply the Fiat blanking plate
    Hope all goes well with the birth, 10 years does seem a long time tho lol
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by merikiito View Post
    lol was thinking the same Sam ..............10 years whow111111
    gosport
    Any idea what gasket it is???
    gosport
    I should of added 2000 last night !!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by stuart813 View Post
    The 1.9 CDTI is a Fiat engine so just pop in and they should know all about it, mind you they are Dealers so maybe not..............
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    They are restrictor gaskets to replace the standard ones, they are not full blanking gaskets. Sounds like you need to give the EGR a good clean out (or a new one) but when refitting, use the Fiat gaskets to keep it tip top (have a search, plenty of threads with the part numbers of thes gaskets).
    gosport
    Ok Thanks
    What sort of price am i looking at paying for one?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Ok Thanks
    Its about £8 for the two (the larger and smaller one).
    gosport
    Cool!
    Think i need a new EGR as i've just finished cleaning it with nearly a full can of carb cleaner and still no change
  1. speedy help appreciated!
    By AKeeNShoT in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2010, 12:49
  2. a wife`s reply
    By eug4611 in forum Comedy & Humour
    Last Post: 28th June 2008, 04:01
  3. Replies: 6
    Last Post: 16th January 2008, 22:20
  4. contractions have started
    By howey in forum General Chat
    Last Post: 9th December 2007, 15:06
  5. contractions have started
    Last Post: 8th December 2007, 08:56
