Thread: Signum CDTi-150 rattling noise
    Regular Member mr-s's Avatar
    Sep 2009
    Shropshire
    Default Signum CDTi-150 rattling noise
    My 54 plate Signum CDTi 150 has developed an annoying rattling noise when pressing/releasing the clutch pedal.
    It doesnt happen when the clutch is engaged whilst driving, only when either disengaged or stationary out of gear (clutch engaged) and i rev the engine - as soon as the revs die back down it rattles briefly around 1500rpm.
    Recently it has developed a loud(ish) intermittent 'clunking' noise too whilst stationary with the clutch engaged (out of gear).
    - it was the wife who noticed it as i was unloading a suitcase out of the car for a family member after a weekend away. To be honest it makes the car sound awful.
    Is this sounding like the dreaded DMF problem?
    Cheers,
    S.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    The first one is the DMF, for sure. I've not heard of the stationary clinking though. Maybe the air-con kicking in..?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    There are places that will do this job for around £600 so its not as bad as it has been
    Regular Member kamar's Avatar
    bradford
    my veccy 150 has a tiny vibration when the clutch is not pressed if i press it the vibration goes away, however what i did notice is when i start the car cold in mornings and rev it even slightly it makes the clinking sound/noise.... c if ur car does this.... no noise when warm though... does sound like dmf....
    Sep 2009
    Shropshire
    Cheers.
    I was half expecting someone to post up 'yes it sounds like the DMF, so start saving as its well over 1k to replace'!
    At least £600, however expensive that still is, sounds a lot better than what Vauxhall want.
    Is there anywhere near Telford/Shropshire that can do it for around that price, and is it a job that needs doing ASAP, or can it wait for a while?
    Thanks,
    S.
    Regular Member DaveW555's Avatar
    Cannock
    I'll do it for 650 and I'm in cannock so not far from you. All genuine LUK parts as well, no cheap sh*t here.
    Sep 2009
    Shropshire
    Quote Originally Posted by DaveW555 View Post
    Cheers.
    Is that for both DMF and clutch?
    S.
    Cannock
    Yeah DMF, clutch and slave and all new fluids.
    Sep 2009
    Shropshire
    Cheers, i'll let you know when i decide to get it done
    S.
    Cannock
    No problem matey, I'll pm you my number then you can give me a bell if you want to get it done.
  1. Rattling noise
    By Lozza in forum Engine & Drivetrain
    Last Post: 10th May 2012, 18:34
  2. Rattling noise over 2800rpm (CDTI 120)
    By rec in forum Engine & Drivetrain
    Last Post: 1st November 2010, 15:39
  3. rattling noise
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 18th January 2009, 02:37
  4. rattling noise
    By signumboy in forum Engine & Drivetrain
    Last Post: 6th February 2008, 20:28
  5. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
