Thread: unbalanced tickover and burning smell
    Regular Member jofenan's Avatar
    nottingham
    Default unbalanced tickover and burning smell
    i have an 08 150 cdti...the engine was replaced by vauxhall under warranty at 43k due to a failed water pump...
    my problem is that occasionally when i stop at traffic lights there`s a huge cloud of smoke from the exhaust...its done this maybe 6 times in ten thousand miles since the new engine
    but the main cause for concern is when the temp guage goes to a third (about 85)..usually it`s straight up...but when it goes down the tickover becomes unbalanced and the car shakes a bit...plus the exhaust gasses smell burnt?..it does this a few times a day
    the car is used as my taxi so doesnt really get hot or cold all day...just stays hot till i finish work!
    i`ve only got 4k left on the warranty so want to get this sorted before they tell me to sod off
    jon
    Check this thread: http://www.vectra-c.com/forum/showthread.php?t=110789
    Its perfectly normal, its the DPF in regen. If you switch the engine off while its doing it then eventually it will clog up and you will have a bill woth lots of £££££££££ on it.
    nottingham
    well thats a wieght off my mind...i wonder what the cloud of smoke was?...not seen it for a couple of months...hoping it was something to do with the engine swap!
    probably a dose of soot being burnt off.
  1. Burning Smell
    By Tam80 in forum Engine & Drivetrain
    Last Post: 13th April 2011, 11:36
  2. burning smell
    By mace in forum Engine & Drivetrain
    Last Post: 7th December 2010, 21:47
  3. burning smell
    By tony stoney in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2010, 19:23
  4. Hmm What's that burning smell?
    By Stevel in forum The 'Off Topic' room
    Last Post: 9th March 2009, 21:22
  5. got my sri!!! burning smell!!
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 21:54
