Thread: Radweld -- Will it hold??
    Regular Member fifesri's Avatar
    Sep 2009
    Fife
    Default Radweld -- Will it hold??
    I have just had to put radweld in my wife's (2000) 2.3 Galaxy as the radiator had a drip drip leak. How long will it stop the leak for ? More importantly if it comes to it what will a new radiator cost ? Cheers
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    k seal better as rad weld can block the heater matrix
    preston
    Always had good results with rad weld, it will be fine for a long time.
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    Quote Originally Posted by bygumlad View Post
    me to i had to put some in 9 months ago and had no problems yet
    stockport
    Thumbs up felixx
    Quote Originally Posted by fifesri View Post
    Hi.I Have an "04"Vectra c.Around February last year,the header tank level kept dropping from time to time,on examination,some plastic mounting had rubbed a hole in the radiator.The stealers wanted around £300 to fit a new rad.Popped in some Radweld and havn't had a problem since!!! Go for it.
    Regular Member vectrasri-j's Avatar
    Sep 2009
    luton
    Engine : 1.9 CDTI 120
    Mileage : 100000
    Sorry to hijack the thread, Where can I get the radweld from? and how is it used?? I've also got this problem where the coolant tank looses water time to time and garage suspects possible radiator leak somewhere. Cheers guys
    Regular Member Exclusive BV's Avatar
    West Midlands
    radweld and kseal very similar to use.
    just shake it up for a bit and pour into the header tank.
    The good thing with k seal is it will 'integrate' with the existing fluids (coolant) so there is no need to flush. just put in and drive.
    You can pick them up from any decent car accessories outlet
    West Midlands
    If there is no edvidence of leakage on your drive, check for beige gunge under the oil filler cap.
    Sep 2009
    Fife
    Not been on for a few days. Thanks for your replies folks much appreciated
  1. Using Radweld question
    By LJ sxi-nav in forum Engine & Drivetrain
    Last Post: 9th May 2011, 13:16
  2. To Radweld or not?
    Last Post: 12th January 2010, 09:29
  3. Anyone know where i can get hold of this ?
    By slow-poke in forum Engine & Drivetrain
    Last Post: 22nd April 2009, 17:41
  4. Hold it
    By MLC in forum General Chat
    Last Post: 17th May 2006, 21:23
radweld for radiator vectra c
