Results 1 to 2 of 2
Thread: CDTI Check engine light
    Sodding Typical on Sea
    Default CDTI Check engine light
    Hi folks,
    Quick opinion sought,
    I just got home and as soon as I was changed set about the airbox to remove the lower baffle. I disconnected the MAF as normal, and removed the small section of flexi pipe from the MAF to the black Cobra pipe. The airbox was full of debris all right! and the filter needs changing so will pick one up next time out.
    I removed the baffle fine put everything back together and have a CEL on now not the spanner one the one on the right amber engine shape.
    I know that I don;t think the airbox got screwed down properly first time I put it all back together so I dis-assembled then re-assembled and it did go on and seal, but CEL is still on.
    Is this connected? and is it a 10 cycle times and it will reset type?
    Appreciate the help, thanks in advance
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    I re-fitted the section of pipe my MAF is on the wrong way round after de-restricting the airbox, and the EML and Emissions lights came up. I would imagine if you put everything back together properly the Emissions ( the yellow engine symbol) and EML lights can simply be Tech 2'd out. It may be that your problem was similar to mine where the flow from airbox to engine has been blocked or obstructed.
    I don't think the Emissions light is on a cycle and needs to be reset with Tech 2. Obviously if there is a subsequent problem the light will come on again.
  1. Vectra C 3.2 - Engine Check Light and Traction Control
    By bigmac22 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2010, 08:13
  2. CDTI 150 engine light.
    By mally in forum Diesel Engine related
    Last Post: 18th April 2010, 16:47
  3. Intermittent check engine light and limp mode
    By Loaf in forum Engine & Drivetrain
    Last Post: 16th April 2010, 10:43
  4. Engine management light on cdti 150
    By peadar in forum Diesel Engine related
    Last Post: 9th April 2010, 23:03
  5. Help on 1.9 cdti sri (engine light)
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2006, 22:03
opel vectra c check engine light
