Thread: Heater blower noise???
    Regular Member stuart813's Avatar
    gosport
    Default Heater blower noise???
    Hi Guys my heater blower keeps making a squeeling noise and is starting to get on my wick. Anyone know what i can do about it.
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Have you had any problems with water getting into the cabin.
    Check out the How 2 for cleaning out your scuttle panel.
    If your blower is squeeling, it can be one of three things..
    1) A leaf or something partially obstructing the airflow within the air-vent trunking
    2) The ventilation flaps on your dash are not properly open or closed
    3) Or the only expensive one..the bearing in your blower motor is possibly corroded or binding up.
    This is common where water has got into the cabin through the pollen filter aperture in the top of the bulk head.
    When it does this, the water flows directly onto your motor and resister pack, causing the resistor pack to go pop, or the motor spindle / bearings to corrode and seize up.
    Remove your glove box to take a proper look at your fan motor.
    gosport
    Ok Thanks not doing it all the time yet.
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    Go in thru the pollen filter and put some 3 in 1 oil in there. Worked for me
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by benwalters82 View Post
    Just be careful where you pour the 3in1 oil, don't want the whole cabin stinking of oil.
    The centre metal spindle is where you need to oil
    There is bags of space to get at the motor, if you take the pollen filter out first...only takes about 20 seconds to remove the filter....dead easy!!
    stockport
    Thumbs up Felixx.
    I went through a faze where my heater kept blowing resistors.Was told it needed a new blower motor.Thanks to info off this site I fixed the resistor using the "Halfords"method!!,however,to the point,whilst I had the glove box out I sprayed the heater motor with WD40,and,for extra measure,also via the pollen filter inlet.
    Resistor still going strong and no noises from the blower motor.Felixx.
  1. heater blower
    By Pete Kincaid in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2017, 18:02
  2. heater blower not doing its job
    By coylo5 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 14:58
  3. heater blower
    By bootneck85 in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2011, 00:40
  4. Heater blower!!!!!
    By mitch in forum Electrical & ICE (including SatNav)
    Last Post: 19th November 2010, 00:15
  5. Heater Blower
    By Woolly in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2008, 18:12
vectra c fan noise
vectra c blower motor
vauxhall sugnum fan
vauxhall vectra noisy heater motor
whining noise coming from my vauxhall vectra c blowers
vectra c heating motor control
vauxhall zadira noise from heater blower
vauxhall vectra noisy heater fan
vauxhall zafira 2006 heating noise
vauxhall corsa heater noise
corsa heater making whining noise
whistle npise from heater vauxhall astra
interior fan whistling in my vectra
qhy does vauxhall astra blower make noise
vectra c heater.noise
noise on fan heater on vrctra
vectra c leaf in heater blower
corsa c noise from pollen filter
vectra 2005 air fan noisy
vauxhall car fan making noise
Opel Astra H heater very noisy
bubbling water sound when blower turned on vectra c
astra squeaking heater
how to remove heater blower vectra c
vectra c heater blower noise
