Thread: Fuel Leak V6 CDTI.
    Full Member
    Bristol
    Default Fuel Leak V6 CDTI.
    I have a diesel leak from the back of my rear left cyd head on my Y30DT. But there is no pipes that side only the filter. Has anyone got a picture of the back of the head they could post or anyone had this problem.
    Full Member
    Bristol
    For some reason there is no diesel leaking in the V. but when you turn car over diesel is leaking for just below the starter motor. I am lost. Is there anyone that can tell me if there is an injector diesel escape in the block to stop diesel leaking going into the oil the expels it from the engine if the injectors leak.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    When we were replacing the injectors on my old V6CDTi we noticed that the only way that diesel could get into the oil was via the pipes under the rocker cover and rubber injector seals.
    Have you checked the fuel feed pipes that go from the filter to the pump (3 pipes on the left side of the engine I think)?
    Full Member
    Bristol
    I will have a look on tueday but the garage has checked the pipes and no fuel leaks. I am at a loss.
    Full Member
    Bristol
    There is no diesel in the oil. The car has now been towed to a denso service centre to try and sort it out, as they can pressureize the system and check every pipe feed.
    Quote Originally Posted by sb1uk View Post
    At least you have one nearby, I can't find one in Scotland
    I am due to visit Wrexham shortly and the car is being taken to an agent near there for inspection
    Full Member
    Bristol
    What wrong with yours mate.
  1. Fuel leak cdti 150
    By stevoxsi in forum Engine & Drivetrain
    Last Post: 13th February 2013, 11:58
  2. 1.9 cdti fuel leak
    By gnomes in forum Engine & Drivetrain
    Last Post: 28th May 2012, 15:49
  3. cdti fuel leak
    By duncmill in forum Engine & Drivetrain
    Last Post: 29th November 2011, 19:39
  4. 1.9 CDTI Fuel Leak Off Pipes.
    By felixx in forum Engine & Drivetrain
    Last Post: 6th February 2011, 18:28
  5. fuel leak
    By mani2002uk in forum Engine & Drivetrain
    Last Post: 5th October 2010, 16:19
