Thread: how do i change clutch on 2.0l dti
    leicestershire
    Default how do i change clutch on 2.0l dti
    hi, folks.
    is changing the clutch a diy job or would you suggest use a garage, as my release bearing is on its way out,
    thanks kez
    Regular Member DaveW555's Avatar
    Cannock
    It depends really, if you've got all the tools required, if you feel you're competent enough to do it or not, and its not a release bearing you have to change, its the slave cylinder, its all one unit and theyre about 80 quid, you can buy a 3 part clutch for about 240 quid for a genuine LUK part. As for whether you do it yourself is up to you.
    Aug 2009
    LEEDS
    ive done clutches before a couple of times, id send vectra into garage! not that easy to do unless you have time and patience
    leicestershire
    thanks for replys, what would the ball park figure on clutch and slave cylinder to be sorted at a garage, any special tools required if done as diy
    thanks kez
  1. Dmf and clutch change
    By Signum150 in forum Engine & Drivetrain
    Last Post: 5th March 2012, 22:04
  2. Can I change DMF and not the clutch
    By marky2027 in forum Engine & Drivetrain
    Last Post: 12th February 2012, 19:47
  3. change clutch as well
    By marko1973 in forum Engine & Drivetrain
    Last Post: 3rd January 2011, 23:46
  4. clutch fluid change
    By nikroc in forum Engine & Drivetrain
    Last Post: 16th November 2009, 23:44
  5. Clutch Change?
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2006, 18:04
vauxhall signum dti clutch change
