Results 1 to 10 of 16
Thread: Gsi creak.....
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default Gsi creak.....
    start the car... no issues.
    clutch in..... no issues.
    into 1st gear...... no issues.
    clutch out slowly, and as the car moves it creaks. its coming from the front but I dont know why, any ideas???
    also, it ticks over at 500rpm when warm, is that right, it seems too low to me.
    thanks if you can help.
    Thats about right for the 3.2, mines the same. As long as it doesn't stall, why worry
    The creaking could be a bush or spring up front. Also possibly the rad mounts.
    Suffolk
    oh right...lol
    what about the tick over?
    hahaha
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by Judas View Post
    oh right...lol
    hahaha
    500rpm when at temp seems reasonable... there's a goodly amount of mass spinning around so it will be slower than the smaller/lighter engines.
    oh right...lol
    hahaha
    Suffolk
    sig, I would love you to have a go in my car to compare, it seems a bit lumpy off the throttle and it seems a tiny bit down in power, or it could be that I'm now used to it....
    I'm sure its ok, its always the same when you change your car, you find lots of little things that your not sure about. I'm sure its fine.
    But, if it helps, run it down to about 30 miles left, stick a load of fuel cleaner stuff in it and take it out for a good hard blast. Hit the rev limiter in second It may help it clean things out, but only if your happy doing that.
    Sean
    Suffolk
    Sean
    I do that about every other tank.....lol
    it returns about 30 to the gallon and still pulls quick enough.
    a lad at work has got a 130bhp seat ibiza and while my car was quicker, the seat didn't embarress itself at all.
    Suffolk
    mind you, the gsi is:
    0.104 bhp per kg
    when the ibiza is
    0.103 bhp per kg.
    not far behind.
    It's only in the higher speeds you'd pull away. It's down to the gearing as well
  1. Almighty CREAK!!!
    By JonV6 in forum Suspension, Wheels & Brakes
    Last Post: 25th December 2012, 14:56
  2. Brake creak
    By bcoss in forum Suspension, Wheels & Brakes
    Last Post: 2nd July 2012, 14:45
  3. gsi creak
    By fletch123 in forum Bodywork & Interior
    Last Post: 6th May 2012, 16:00
  4. What the creak!!!
    By pix in forum Vectra C / Signum Troubleshooting
    Last Post: 26th June 2011, 01:32
  5. b pillar creak
    By ROB WOODHOUSE in forum Bodywork & Interior
    Last Post: 29th March 2006, 17:19
