Results 1 to 10 of 23
Thread: Exhust system on 3.0CDTi Y30DT
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    Default Exhust system on 3.0CDTi Y30DT
    can any help me
    I am after a full drawing lay out of the said above
    from the manifold to the back boxes and where the cat is how many flexy pipes
    and how big is the middle box and whats just in front of it
    cheers lads I hope you lot come good for me on this one
    Regular Member the fisherman's Avatar
    manchester
    you can call round to mine if your in manchester and have a look if you like m8 if its just to see it or is it the actuall drawing your after
    Jan 2006
    Dalriada
    My dealer faxed me a copy of my exhaust set up Ian - im sure they would do it for you too if need be?
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    just after find out where the cat is
    whats in front of the the middle box
    I just cant see from ground level
    so I throught if any of are wizz kids could find some drawing with each box joint and flex
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    Quote Originally Posted by Steven View Post
    cheers steven if i cant get any help by tomo
    I drop in the dealership tomo night
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    But please still if any one got some think post up
    or will TIS have it on
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Hope this is ok Ian.
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    Hi Ian if you need to see under the car i have a four post ramp at work we could put it on , its in Chorley though mate just yell pal if you need
    Steve
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    sounds to me like someone is going to be having a play.....
    Midlands Mod Shop - NFFC.
    That diagram can't be right, as the rear boxes are completely separate with an option to replace either
    Mine has a short Y pipe section directly after the centre section
    There is then a crease at the end of the Y, where the pipe can be cut if one of the rear boxes needs to be replaced
    I'll try and take a photograph when my car is in for it's MoT on Thursday
  1. Strong Exhust Smell in car - just started happening!!
    By suresh.chohan in forum Engine & Drivetrain
    Last Post: 17th December 2012, 20:39
  2. Strong Exhust Smell in car - just started happening!!
    By suresh.chohan in forum Introduce yourself.
    Last Post: 17th December 2012, 18:34
  3. exhust thick black smoke
    By faizyan6000 in forum Troubleshooting
    Last Post: 29th February 2012, 14:22
  4. Y30DT again
    By Celes in forum Engine & Drivetrain
    Last Post: 7th May 2009, 14:22
  5. twin exhust query
    By damoore1983 in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2009, 23:42
